Using this tapping program, we are getting a spindle overload alarm on our V2XT when tapping more than 8 positions. Is the spindle RPM of 750 too fast? Should I program a M0 and change to low gear to perform tapping? Thank you so much. N2 T2 M6 ;(1/4-28 TAPPED HOLES) S750 M3 G00 X2.1793 Y-.25 Z.1 G84 X2.1793 Y-.25 Z.18 F26.78 G80 G0 Z.1 M22 |
i would not have thought 750 rpm too fast for a 1/4 inch tap. what z depth are you tapping? check the parameters in your G84 block, i have not done any machining center tapping for a few years but there looks to be something missing, like the clearance height, is it the R word?, and should the Z word be negative -??? if the machine has a low speed range, try changing to it and selecting a spindle speed from there. good luck atb axis |
Here's my 2c, First try this with the Z offset with a +2.0 to ensure it will work with your machine. N2T2M6 S750M3 G00 X2.1793 Y-.25 M08 G43 H2 Z.1 M29 G84Z-.(WHATEVER YOUR Z DETH NEEDS TO BE ENTERED HERE) R.1 F26.7857 G80 G00 Z4. M09 G40 M05 G91 G30 Z0. This program is from SmartCam and is formatted for Fanuc controls. It is fairly generic and is set for rigid tapping. The M29 locks your spindle rpm to your feed rate. I always carry the feed rate out to 4 place to ensure a smooth tap and less liklyhood of tap breakage due to not having the proper feed. Take your RPM and devide by the pitch of your thread and that gives the feed rate. Good luck and keep posted if this does not work for you. Russ Jackson in SW PA N2 T2 M6 ;(1/4-28 TAPPED HOLES) S750 M3 G00 X2.1793 Y-.25 Z.1 G84 X2.1793 Y-.25 Z.18 F26.78 G80 G0 Z.1 M22 |
| 5S Dude, Remove the X & Y addresses from the G80 OpCode line. If your control skips the initial X & Y location then include the initial X & Y addresses on the line following the G80 OpCode line just as you would with any subsequent X & Y addresses. Servo |
| The problem is not in the program. The problem is in the design of the machine. The current needed to reverse rotation of the motor puts a strain on the overload. Less spindle reversals per minute is the only solution. Sorry. George
| axis overtravel; thank you for the quick response. I currently interpolate a .211Ø x .22 deep blind hole with a 3/16 2-flute center cutting end mill. I chamfer each hole 45° x .015 before sending the ¼-28 three flute high spiral flute flat bottom tap .180 deep. It works like a charm on the parts that have 8 tapped holes in it but when the same process is applied to the part requiring 16 tapped holes my poor Bridgeport gives me the “spindle overload message.” I of course do not want to place undue stress on my baby so I may resort to an articulated-arm stand-alone tapping unit and simply tap the holes manually. Remsandpets; thank you as well, I do not believe the DX32 control is equipped to process rigid tapping so I’m currently using a spring loaded tension tap holder from Procurier. The tapping process has yet to snap a tap as it simply gives the “spindle overload alarm” and requires a machine shut down and resetting the switches inside the control cabinet. Servo Wizard; thank you for your valued input as well. Machintek; thank you for your answer to my dilemma! I do realize the V2XT is more a tool room mill than a full-blown production machining center so no need to be sorry. This part time hobby has blossomed completely out of control and I am beginning to see the machine limitations now. In your opinion, is perhaps a larger motor upgrade possible as I need the full length advantage of the V2XT table over say a Haas, Fadel or Hurco type machine. Or should I simply move the tapping process to a Tapmatic equipped articulated arm setups and tap manually? Thank you all so much for your devotion to this great site!! You all have been very supportive and I hope I can one day return the favor! |
| I've noticed on a few Lathe tapping programs some of the programmers prefer to start the tapping cycle .2 off the face of the part and I was wondering if this may have any impact on vertical tapping cycles as well. I will post results as they happen. Thanks again. |
| " I've noticed on a few Lathe tapping programs some of the programmers prefer to start the tapping cycle .2 off the face of the part and I was wondering if this may have any impact on vertical tapping cycles as well." The reason for starting 0.2 of the face is to allow the axis and spindle time to synchronise. |
#10
| Hi there, I am having problems tapping on a cnc mill with fanuc omd control. I am tapping 1/2 bsw thread and hole is just reamed when the tap comes out. my program is as follows: can anyone help N2 T15 N4 M6 N6 G0 G90 G54 X-1.125 Y1.125 N8 S500 M3 N10 G43 Z0.1 H15 M8 N12 X-1.125 Y1.125 N14 G84 G99 X-1.125 Y1.125 Z-1.25 R0.1 P0 F4.0 N16 X1.125 Y1.125 N18 X1.125 Y-1.125 N20 X-1.125 Y-1.125 N22 G80 Z2.0 N24 M9 N26 G28 G91 Z0 N28 G91 G28 Y0 N30 M30 |
#11
To tap a 1/2 British Standard Whitworth Thread Data; 1/2ø 12-Threads Per Inch 0.0833-Pitch in Inches 0.3932-Core Diameter Use a Letter Z (10.5 mm) Drill. Change spindle RPM to S200 and feedrate to F16.6667 Let us know how it comes out! |
#12
| I’ve used a V2XT machine for 15 years. Didn’t know you could even start the spindle much less reverse it in the program. Are you using a tapping head that reverses rotation? The DX32 controller is quite capable of rigid tapping on machines that have servo driven spindles. Use the M28, & M29 codes to toggle it in and out of rigid tap mode. As a suggestion, have you considered thread milling instead of tapping? |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| V2XT with a New BUG up its A$$ !! Again... | v488 | Bridgeport and Hardinge Mills | 2 | 05-26-2008 01:55 PM |
| rigid tapping issues | stebanski | Haas Mills | 4 | 06-14-2007 05:56 PM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
| tapping head vs hand/cordless tapping machine.... | InspirationTool | General Metal Working Machines | 6 | 09-12-2005 08:10 PM |
