Old 05-21-2008, 08:57 PM
NC Machine is on a distinguished road
Bridgeport series 1
I recently purchased a Bridgeport series 1 (2H.P.) mill that is in GREAT shape, but there are a couple small problems I need to work out before I can turn the spindle on and make some metal fly. So I decided to post up here because I respect the advice I have read over the last while. I would appreciate any advice anyone can give on any of these subjects as I am not familiar with these topics.
1-I am looking for a phase converter to run the machine. I have NO experience with phase converters as I have always worked in a shop that had 3-phase power readilly available. What are the pro's and con's of both, if any. I bought this machine to put in my garage and I am ready to turn the spindle on.
2-The mill has a Brigeport DRO that when I fist plugged it in would turn on and had fully displayed numbers, zero's. When I moved the table the only thing that would happen is that the tenths would go from 0 to 5 and never register in the .001 of anything higher. I took a friend home that helped me move the machine into my garage and when I got home the DRO was reading perfectly. Now everytime I turn it back on it just does the same thing with the reading never changing in any of the other numbers. Does it just need a thorough cleaning (what with), or is it loose wires? I forgot to mention it has glass scales.
ANY advice that could be sent my way would be GREATLY apprecated. I have been machining since 1989 and I am excited to turn this on and have some fun.
Old 05-22-2008, 12:34 PM
Did I put this in the wrong topic/forum ?
I thought by now I would have some sort of responses
Old 05-22-2008, 01:54 PM
keebler303 is on a distinguished road
Don't be in a hurry, I know you're excited.
On the phase converter, CNC zone has a whole forum dedicated to this, you can find the pros and cons there. I have only used rotary phase converters. One advantage with an electronic one is you can get a VFD and then have variable speed drive. Other than that, you'll have to check into the specifics in that section of the zone.
http://www.cnczone.com/forums/phase_converters_vfd/
Your DRO problem sounds like loose solder joints/wires. It is reading the movement, its just not changing the display. Does it show .0005 or is it just the 5? A good cleaning and inspection would probably help. I'd start with compressed air, followed by a rag with some alcohol or thinner for the greasy stuff. Then look for loose connections and crappy solder joints.
Good luck
Matt
Old 05-22-2008, 03:32 PM
http://www.cnczone.com/forums/forumdisplay.php?f=273
I will be surfing that tonight THANK YOU!!!
Good luck
Matt
All properly placed zero's show up on the DRO, it's just the .0005 reading that changes. I will try, softly blown, compressed air at first while looking for loose solder connections. Then I will try your other suggestions. .
I am anxious to turn my mill on so please forgive my "shortness". I have been wanting to buy a mill for the garage for atleast 10 years and now it's there and I can't do nothing with it YET, been there for 2 weeks now!!!
THANKS TONS MATT!!!
Bridgeport CNC Series 1 vs Series 2 jshank Bridgeport and Hardinge Mills 27 05-26-2012 08:51 AM
Problem- bridgeport series 0ne valmet58 Bridgeport and Hardinge Mills 1 02-11-2008 03:06 PM
Bridgeport Series 1 CNC ID markhas Bridgeport and Hardinge Mills 2 05-30-2006 10:06 AM
Bridgeport series 1 or 2 ?? drill Bridgeport and Hardinge Mills 5 11-27-2005 08:17 PM
Bridgeport Series 1 CRAZYRICH General Metalwork Discussion 2 07-27-2005 07:54 PM
