Old 05-20-2008, 01:27 PM
kewl_cat is on a distinguished road
Boss 5 Series 1 Bridge Rectifier
I just had a second bridge rectifier go out on my Boss 5. 2nd in about 2 months. Any ideas why these would keep blowing. I have about 56V output on the T2 so voltage seems ok. I installed my spare and the machine is back running. Current on the ACC board is 7.9-8.0A. I am out in the woods a little and voltage can be poor sometimes. I have voltage drops sometimes. The electric company says it is not enough to worry about but I was wondering if voltage drops or spikes could be the culprit?
-rob
Old 05-20-2008, 05:03 PM
79TigerPilot is on a distinguished road
Don't know anything about your particular rectifier but three common things come to mind. Over voltage, over temperature and over current. Too high a reverse voltage for the diode's PIV rating will kill it very fast, these usually come form line transients or in some cases from inductive loads or use of too low a PIV rated diode. Too high of average load current or disconnected heat sink can over heat the device and kill it. This is usually the easiest to detect with a thermal probe. Another killer is a single cycle current surge either from line input transients, load transients or the inrush current from the filter capacitors as they charge up.
Craig
BOSS 5 Axis Drive Bridge Rectifier? Eric Bridgeport and Hardinge Mills 7 10-24-2006 04:04 PM
Bridge rectifier go poof blfinche Hobbycnc (Products) 7 10-18-2006 07:11 AM
bridge rectifier output najnielkp General Electronics Discussion 3 07-10-2006 11:05 AM
Bridge Series II CNC,Boss 6. Begging for Help Jerry7 Bridgeport and Hardinge Mills 8 02-19-2006 12:48 PM
bridge rectifier osdhillon General Electronics Discussion 4 12-30-2005 09:24 AM
