Old 05-13-2008, 07:46 PM
serviceman's Avatar
serviceman is on a distinguished road
bridgeport mill head
hello
does anyone have a service manual for a bridgeport mill head? i need to know how to set the gear shift lever, i had the varispeed belt and the timing belt off and the main bull gear moves up and down on a spring but i am not sure where to set it when i clamp down the screws on the shifting lever. the machine seems to slip in low gear under power and the shift lever seemed to be in the wrong place when i started. when i put it back together it makes some noise now, anything i should be aware of when i put it back together. any help would be great thanks.
REYTECH Machine Service Corp. CNC repair NY, NJ
http://www.reytechmachine.com
Newbie- Bridgeport M head questions BBBBill Bridgeport and Hardinge Mills 4 03-30-2010 08:34 PM
Bridgeport 2J head noise jbongiov Bridgeport and Hardinge Mills 7 02-24-2008 07:54 PM
Bridgeport J head - Do I need this???? bill south Bridgeport and Hardinge Mills 1 01-29-2007 03:28 PM
has anyone seen an aluminum table for an old J-head bridgeport mill? xhardwaremanx Bridgeport and Hardinge Mills 2 11-19-2005 02:06 PM
M-Head Bridgeport for $650 - E-bay mxtras Bridgeport and Hardinge Mills 2 09-13-2005 09:39 AM
