Old 05-09-2008, 08:54 AM
Dirky is on a distinguished road
Need Timing Belt # or specs. Bpt series Interact 2
Hi Guys. I have not been around much , busy with work. I need the correct part No for the X axis Cogged drive belt on my Bridgeport series 2 Interact 2. Hardinge gave me the number 21577994. But I cant find a cross ref to a good available part. I do not have the old belt to match so any size specs or numbers would be helpfull. Thank You
Old 05-11-2008, 05:56 PM
Paul cs is on a distinguished road
The bridgeport manual has 1577994 for the part, the spec of the belt is a HTD 720 8M 20.
Hope this helps,
Paul.
Old 05-14-2008, 02:35 PM
Thank you for the help,but I cant find a belt anywhere with that number. I found what someone says is correct #11750057. (have it on order ) And could you clarify the spec on the belt...length..no of teeth...width ? Thanks
Old 05-14-2008, 02:45 PM
OK Paul....my brain just kicked in 720mm long, class 8m, 20mm wide. Thank You
Old 05-27-2008, 09:36 AM
Update re X-axis cogged belt. I have recieved the belt..Part# 11750057. It is a good fit. Bpt # was 21577994. Also a 720-8m-20 is a correct fit. Looks as though any of these numbers are a good sub. Thank You all. I hope this info will help others in future
Bridgeport Series II Interact 4 Z-Axis Timing Belt UKRobotics Bridgeport and Hardinge Mills 5 01-04-2008 04:47 PM
Timing belt and pulleys samakthachai Laser Engraving & Cutting Machines 8 10-24-2007 11:31 PM
Timing belt as a rack? jacampb2 Linear and Rotary Motion 6 09-25-2007 07:21 PM
A New Series of 16 Timing Belt Clamps from SDP/SI carolpratt Product Announcements & Manufacturer News 2 12-27-2006 02:41 PM
timing belt reduction drwc Benchtop Machines 6 05-23-2005 03:31 PM
