Hi, I think my feed override control is bad. As soon as I move it off zero, it seems to go wide open, with nothing in between. It has always been that way, but I managed anyway. I recently got a DoAll mill with Centroid controls, and its feed override works the way I thought it should, with speed gradually increasing as I turn the dial. Would the Bridgeport fix be as simple as replacing the potentiometer? Thanks, Bill Gillen |
| Could be. A potentiometer is a variable resistor. Put an ohm meter on it between the center leg and either outside leg. It should go from zero to its max value in a linear or "audio" curve. If the potentiometer is OK, then it may be the board. George
Hi, mr. Gillen I have a bridgeport knee mill with the same control and well this is my first time with this kind of control, So, I'm using mastercam to generate the part programs , and I would like to set it up the DNC from my desk computer but I do not know the DNC set up. can you help me with it. thankyou. sincerally: jose aguillon |
| Lock out feed rate override | Daves 41 | Haas Mills | 21 | 04-21-2008 05:14 PM |
| feed override keys | elpete0068 | Mach Wizards, Macros, & Addons | 2 | 01-16-2008 01:44 AM |
| Mach 3 & Feed Rate Override | aus-newb | Mach Lathe | 1 | 11-21-2005 06:56 PM |
| Feed Override | SCOJEN | DIY-CNC Router Table Machines | 0 | 01-24-2005 12:56 PM |
