Old 05-05-2008, 10:58 PM
lazerracing is on a distinguished road
Plain language conversion
Hello; Can someone tell me what is G17 18 19 in "plain language" Heindenhain
Old 05-06-2008, 03:58 AM
kdhBOSS5VRAM is on a distinguished road
Axis Definition
I believe it is defined in the tool call line. The Z in the tool call line tells it everything rotates around Z like a G17. I know if you put a Y in that line it will do a drill cycle in the Y axis but I never tried milling an arc but that is probably how it's done.
Kevin
G203v, Plain BOB, Losing Steps pzzamakr1980 Gecko Drives 31 05-08-2009 10:42 AM
Need Help!- need a manual for Heald plain 271 tjenkins007 Want To Buy...Need help! 0 03-20-2008 11:34 AM
Need Help!- Feed Plain jaangi General CNC (Mill and Lathe) Control Software (NC) 0 02-06-2008 04:10 AM
plain language to iso delbert Bridgeport and Hardinge Mills 9 02-02-2006 09:59 PM
McMaster Nylon Linear Plain Bearings? Jcadwell DIY-CNC Router Table Machines 3 10-26-2005 06:32 PM
