Results 1 to 5 of 5
Thread: Connecting BP VMC directly to LAN
    Apr 2008
    Question Connecting BP VMC directly to LAN
    I am new to all of this, to avoid confusion, the question below was copied directly from my e-mail.
    Can anyone out there offer any advice?
    Is our Bridgeport Mill Model TC1G Serial TCY-0121 capable of having a card added "Network Interface Card" that would allow direct access to the hard drive, rather than having to access the hard drive via a com port sending data via a communications program or floppy disk?
    Cheez
    Apr 2008
    I don't know how old your machine is or what control is on it but the newer ones with the Heidenhain controls you can already do what you asked. Heidenhain's communication program TNCRemoNT does that thru the comm port. Gives you direct access and at bauds up to 115,000. I use it daily and it works great.
    Kevin
    Apr 2008
    Kevin,
    Thanks for your reply.
    We are running a BOSS controller from 1997-98
    Cheez
    Moderator
    Nov 2004
    The TC1G has a DX32 control, PC based. It has a CIB (control in a box). The mother board is a half size, all in one, industrial unit. It probably came with a Disk om a Chip. Typically a 8 MB unit. A hard drive was optional. Your mother board may have a ethernet/lan connector on it. I know the later ones do. The problem is you are running DOS and you need drivers for it. I have quite a few mold shops that have installed ISA or PCI lan cards on earlier full size mother boards, loaded WIN3.11 for workgroups and move massive programs that way.
    George
    Apr 2008
    George,
    Thanks for your quick response. I wasn't in yesterday. This forum is something I've looked for for a long time.
    Chuck
    1. Hacking A Printer To Directly Print PCB's
      By epineh in forum General Electronics Discussion
      Last Post: 10-24-2012, 06:55 PM
    2. Connecting rod
      By ACME in forum I.C. Engines
      Last Post: 08-11-2007, 01:09 PM
    3. Connecting to Microscribe 3dx
      By robinsoncr in forum Digitizing and Laser Digitizing
      Last Post: 03-03-2007, 02:26 PM
    4. connecting
      By KrashKing405 in forum Open Source Controller Boards
      Last Post: 07-26-2006, 06:30 PM
    5. Need help connecting laptop to CNC
      By flyguy1254 in forum General Metal Working Machines
      Last Post: 10-20-2004, 07:28 PM
