Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    Aug 2004
    I am a new student learning CNC programming/machining. I am working on a Bridgeport Interact 412 VMC with the Heidenhain TNC 151 controller, and using MasterCam Version 8. So far everything is going well, except for one problem.
    The manual says that the Heidenhain has two running modes. One mode is “Program run 1-block,” (top row, middle button) meaning that it will run one block of code at one time. In order to advance to the next line of code, I will have to push the “cycle start” button. This I understand.
    The other mode is “Program run-full sequence,” (top row, 2nd button from right) meaning that it “should” run the complete file by pushing the “cycle start” button only once.
    My problem is that when I upload the file into the Heidenhain controller, and then go to the “Program run-full sequence” mode, I still have to manually push the “cycle start” button each time so it can go to the next line of code. According to the manual, it is supposed to run though all the lines automatically. It seems like it is running in the “run 1-block” mode all the time.
    I have also noticed that when the file is uploaded into the controller, the program lines start at #0 (Begin PGM 100), and then there is a big gap and the program begins much later (around line 70-or so depending on the program). I tried to delete the extra gap, but the controller will not allow me to do so.
    If I were to go to “Program-full sequence” and upload directly from the computer, the machine will run perfectly, but the down side is that the file is not stored into the Heidenhain controller. It must be uploaded every time. In this mode, I also notice that the code starts at line 100 (instead of 0) and it goes straight through to the end (without any gaps). The machine works perfectly this way.
    I was thinking maybe I am using the wrong post-processor? Or there might be some kind of setting on the Heidenhain that I don’t know about?
    I do also have a picture of the Heidenhain controller buttons available.
    I really appreciate any help you can provide.
    Thank you in advance!
    Larry
    Just learning how to program CNC machines...it's pretty fun....until you crash :-(
    Sep 2003
    Atlantis
    Larry,
    Are you sure you are using the correct button?
    Why dont you post a copy of your programm so that I can check if there is something wrong with your programm.
    A phone call to Heidenhain service or e-mail could also help.
    Aug 2004
    Quote Originally Posted by Mouldmaker
    Larry,
    Thanks for your help. I have called heidenhain customer service and they told me to reload the parameters. It works perfect now!
    Jan 2006
    U.S.
    Bridgeport Interact 412/Heidenhain TNC 151 controller question
    I where are you located and can you help me I am looking for a tuter. Just wonder email back. thanks johnathon
    May 2009
    Türkey
    İnteract Haidenheim 151 B
    Hello friends ..
    I also have a Interakt 151st. (Bridgeport İnter.2)
    What I would ask you ..
    The machine is a 3X 110.Volt ..
    Therefore it Does ne transformer.!
    How much Kw or Amper this transformer must be ..
    Sorry my English is not good.!
    Thanks to All.
    yasin..
    Jan 2010
    pakistan
    Heidenhain TNC 150b parameters please
    Jan 2010
    pakistan
    Heidenhain TNC 150b post posser available in master cam 9/
    Heidenhain TNC 150b display is operation parameter erased in Ce bu tan click no display MPOO line ?noPLEASE?
    AND NC SOFTWARE?
    Jan 2010
    pakistan
    MPOO LINE IS NO DISPLAY SHOW
    Jan 2010
    pakistan
    MACHINE IS ONE display is operation parameter erased
    IS CE BUTANE CLICK IS NO LINE MPOO NO SHOW DISPLAY
    Apr 2010
    i need a help to find out a coolant pump for bridgeport interact 412.....
    please help me... thanks in advance.....
    Jan 2010
    pakistan
    MP OO NO LINE
    Jan 2010
    pakistan
    larrynsr HI
    DNC SITING YA CABLE FLOUT AND POST POSASAR
  • Page 1 of 2 12 LastLast
    1. Bridgeport interact software help!!!!
      By martie in forum Bridgeport and Hardinge Mills
      Last Post: 02-23-2005, 08:10 AM
