Have a EZ Trak Series II Mill, upon loading up the system comes up with a Drive fault error - system not home. Upon trying to home an error comes up "Axis Drive turn off" Current testing. Green lights on amplifier Red lights go out. Checked fuses Checked E-Stop Checked Limits Switches Checked Cables - Wires - Connectors Checked Power Supplies Reseated Cards - Memory - Cleaned Contacts Cleaned Encoders Checked - Cleaned motor brushes Visual inspection of boards Anyone have a suggestion to possible cause/problem, I'm currently at a dead end on any other posible testing to perform or possible things I've could of missed. Help Appreciated! |
| Turn machine on. Let it boot. At that point the green LED on the drives are on. Are the RED also on? If so this is correct. X and Y handles should nove with no effort. Press 3 to enable the drives. At this point the RED LED on the drives should go off and stay off. Do they? If the RED LED are off, the drives are on. Try moving the X or Y handle. They should resist your effort. If so maybe the BMDC is not seeing that the drives are on. Check the fault lines back to the BMDC. Also check mother board for damage around the area of the CMOS battery. Just a thought. George
Thanks Machintek, For your present and past postings. Your posting on 06-02-2007 nailed it. "lost your position loop. Typically a bad L1 inductor used as a fuse on the BMDC board." I checked the L1 and L2 on BMDC board and found a bad 3/4 amp pico fuse (The L1 - L2 had been repaired before on the BMDC board) Thanks again, MTech2 Note: (Beleaved cause) Dust built up in the ATX power supply causing a voltage spike to the L1 L2 Inductor on the BMDC board. |
| Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. | kreutz | Stepper Motors and Drives | 3 | 07-03-2008 06:57 PM |
| Need Help!- 6 axis screen of mach3 | ayhan | Mach Software (ArtSoft software) | 0 | 02-21-2008 04:24 AM |
| EZ TRak DX w/flash drive will not home | ataylor_316 | Bridgeport and Hardinge Mills | 7 | 07-01-2007 06:01 PM |
| Home Made 4th Axis with Harmonic Drive Unit! | widgitmaster | Benchtop Machines | 30 | 06-05-2007 11:14 PM |
| New 5 axis screen set I've been working on | Darc | Screen Layouts, Post Processors & Misc | 14 | 04-10-2006 02:38 PM |
