Old 04-14-2008, 08:19 PM
tpmx57 is on a distinguished road
Mach 3 with HillBilly BOB
I have installed a Hillbilly BOB on my series II cnc and am having problems with the x-y-z axis not moving the correct distance.
I had my motor tuning set to 2000 steps per.
I wasn,t getting 1.000" axis movement per 1.000" programed distance.
I started changing the units until I got an exact movement for programmed amount.
This is what I ended up with,x axis 2030, y axis 2040 and z axis 2000.
these settings give me .500 travel per .500 programmed distance.
Is it normal for these amounts to be different?
I expected the values to be the same at least on x & y.
Did BP use different leads or pulley ratios on these machines?
THANKS!
Using mist coolant with Hillbilly board (Series I BP) Mr. Technical Bridgeport and Hardinge Mills 9 11-19-2007 09:01 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Mach 3 no spindle - but OK in Mach 2 zcases Mach Software (ArtSoft software) 9 07-31-2006 07:38 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
