All, So being it was cold here, I turned on my machine to let it warm up and all the lights on the control panel were lit. So I let it be for a bit, and when I came back to it, The only light left lit was the limit light. All the display lights on the red light readout were out and no axis's will move. Anyone have any idea what could be wrong? I do appreciate all the help! |
| All LED are dependent on 5VDC. Check power in, fuses, and logic power supply. George
| Check your Power Supply. It is the big White framed box in the cabinet on the right side of the machine. You'll see test points like 5 volts, 12 volts and -12 volts only check the 5volt r points not the ur points. If the 5 volts is bad check fuse #20 sometimes the fuse goes bad. The Limit light works off of 24 volts so your 24 volt power supply is okay. If the whole power supply is bad I take a power supply out of a desktop computer and unhook the old power supply and put it in. You can purchase these for around $10 at used computer stores. You need at least a 20 amp power supply on th 5 volt side. Rich |
| R2V3 power up issue Boss 10 control | wcarrothers1 | Bridgeport and Hardinge Mills | 1 | 05-18-2009 01:07 AM |
| Help with BP series I with BOSS 4 control | rhemp | Bridgeport and Hardinge Mills | 1 | 08-07-2007 10:37 AM |
| My DIY control panel | DennisCNC | CNCzone Club House | 6 | 10-02-2006 10:24 PM |
| BOSS 5 G-Code Using Interface Panel? | Eric | Bridgeport and Hardinge Mills | 2 | 09-25-2006 10:26 AM |
| Building my control panel | ChrisJ | General Electronics Discussion | 0 | 03-02-2005 08:09 PM |
