Old 03-24-2008, 10:01 AM
Ranchero50's Avatar
Ranchero50 is on a distinguished road
Question DX 32 coolant enable G code problem
On my 308 I can enable the coolant pump through the coolant subscreen and run the motor, but the motor won't run under a M7 or M8 in the program. The monitor screen shows coolant off for M7 and coolant aux for M8.
Am I doing something dumb?
Old 03-24-2008, 05:47 PM
Moderator
machintek is on a distinguished road
Is the spindle ON when you try the coolant M function?
George
Old 03-24-2008, 09:18 PM
Ranchero50's Avatar
Yep, went back over it tonight after work and everything coolant wise worked. Fly cutter had a M04 then the next line had M07 and away it went. Did a M08 on the .250" EM and the pump ran there too. I did have my Y axis backwards on the program, took a bit to figure out (center of part =X0, Y0). Three passes with entry and exit arcs at the end of each depth cut. MDF looked nice when cut so hopefully the aluminum will too. Tomorrow should have a 90~ counterbore bezel edge and then drill the mounting holes for the part.
Jamie
Need Help!- Is M8 common Code for coolant? SpeedsCustom LinuxCNC (formerly EMC2) 15 04-03-2008 08:13 PM
M code for coolant SIG Daewoo/Doosan 5 11-29-2007 09:51 PM
How to control coolant by G code? Simonetz Tamás Syil Products 9 09-03-2007 12:44 PM
Syil(Spindle, Coolant pump G-code Control Finish) syil Product Announcements & Manufacturer News 4 08-27-2006 10:52 AM
enable BB code in member signatures? mvaughn Forum Questions or Problems 3 10-04-2004 09:57 PM
