Gentlemen, I recently purchased an older Bridgeport (Series 1) with a 1hp motor. I started searching for a 3-Phase Converter and I was told that my converter should match the HP of the machine. In my case I would then be looking for a 1HP 3-Phase converter. But I have not found a converter that is anything less then 3HP. Am I looking in the wrong places, or was my advice incorrect? I am assuming (and I really hate doing that) that a 3HP Converter is what I should be using. I based this assumption on what I have read about other Bridgeport owners and commercial converters. Corvair.Flier |
| Well, I'm certainly no expert, but a bigger phase converter can always power a smaller motor. Most of the references you see to matching (or exceeding by 1.5x) HP are related to the bigger machines. If you're sure you only need it for this machine, Look into VFD (variable frequency drives). I used my VFD on my BP and it fit the bill perfectly... until I bought a bigger machine ![]()
__________________ in order to learn... not save money. |
| Check out www.driveswarehouse.com Plenty of different size and featured Hitachi and other VFD drives.... Don't buy the cheapest unit - buy one that has a braking unit INTERNAL.. You will likely need external braking resistor. I have both and L200 1 hp unit, and an SJ200 2 hp unit. Without a brake, flipping the speed down quickly, or just hitting "stop", will likely trip the unit as the motor turns into generator (it does with my 2h motor). I use a 50 ohm 500 watt braking resistor and can stop my 2hp motor in 1 second, from as high as 4000rpm. If you use a larger vfd to run a smaller motor, be sure to change the various registers that control the max motor current etc. |
Kayak and Lakeside thanks for the information. I was leaning on the side of the VFD until Kayak asked if my Bridgeport was the only thing I would be using the 3-phase for. It got me thinking, I bought the Bridgeport from a gentleman that also owns a nice lathe. And he said that he may be interested in selling sometime soon and that he would give me the first opportunity at buying it. So now I may be leaning back to the Rotary Converter. SO I will have to think about this a little more. But I really appreciated the information. I had never heard of a VFD before and find it very interesting. Corvair.Flier |
| If you don't care about the variable speed, braking or other vfd feature.. a rotary converter is an easy solution. You will still need 3 phase motor protection, breakers, switches etc, and this can easily cost more than the VFD approach. Personally, I like what a vfd offers, and have/will fit them to each of my machines. I have a very nice 1hp (start) rotary converter that is gathering dust... |
| I've been running my series 2- 2hp motor off a 10hp rotary converter. It's cnc rated which I believe means it stays plus or minus 3% on the output. With shipping and brand new I have around $500 in it. Very easy to hook up....just had to buy some extra wire. Everything else was prewired and ready to go. Had it hooked up and running in about an hour. I was told to at least double the converter rating for the motor you want run. So I could of easily used a 5hp converter but had the same thoughts as you and may hook up another machine to it also. If your interested I can hook you up with the place I got mine. Louisiana, if I remember, is where it shipped from. |
| Hi corvair.flier I have a 7.5 hp that is new & has been used one time for a tryout it is easy to wire & has a softstart which is important I want $275 plus shipping this has a Baldor motor with rubber feet you can email me if you are interested they cost way more than this the unit is made by Gentec & is cnc rated
__________________ Mactec54 |
| I'll ditto what lakeside said. I only bought the VFD because I needed 3-phase. I had no idea about the other benefits. BUT now I am so use to using it to slow down my speed ups, speed up my slow downs, and fine tune my speeds, I don't think I'll ever go back. You can make a rough cut then speed it up and make a final pass without ever having to deal with the pulleys. The only reason I can't get away with it on my lathe is because they are pretty expensive for 5+ HP... and because I picked some inexpensive parts to build an RPC . If you get one for the mill you won't be sorry, even if you end up needing a converter later.
#12
| i made my own 3-Phase Converter for my Bridgeport, pretty easy to and i can not tell the difference look at this link www.metalwebnews.com/howto/ph-conv/ph-conv.html |
| 60 HZ to 50 Hz converter for 3phase motor | bherr | General Electronics Discussion | 12 | 08-12-2011 12:54 PM |
| Can I use the same transformer for 240 and 480v 3phase? | carbidecraters | Fadal | 3 | 09-28-2007 07:09 AM |
| Phase converter for Bridgeport V2XT | DF-ENTERPRISES | Phase Converters and VFD | 1 | 08-30-2007 09:03 AM |
| Rotary phase converter for Bridgeport 2J Series 1 KM-1 2HP setup? | modernprecision | Bridgeport and Hardinge Mills | 12 | 07-01-2007 06:43 PM |
| 3Phase motor, is it good. | Alan T. | General Electronics Discussion | 2 | 11-30-2003 11:01 PM |
