Old 02-29-2008, 08:21 PM
bbrreid is on a distinguished road
electro-magnetic brake
can anyone advise on the spindle brake on my BP series 2.
I got the machine with the brake disassembled with the advice that it wasn't
working.a local electrical workshop tested it and found it to be working.
I put a meter to the 2 wires that connect to the brake and found a constant voltage with the spindle on and off surely this cant be. the brake is made by Matrix who I do machining for so I can get a new one but there's not much point if the old one is working. anyone had the same problem.
BR
Old 02-29-2008, 11:01 PM
Moderator
machintek is on a distinguished road
Very little data like what control? which model Bridgeport?
George
Old 03-01-2008, 03:27 PM
Sorry, Heidenhain 151 Interact 2 with programable spindle. not the one with the air brake
and air speed control the later model. any help more then welcome
Brian
also having trouble uploading programs but not downloading.its not the PC software or the cable as they work with my 155 and 355.I'm sure the guy who was tring to fix the brake was messing with the parameters
BR
Old 03-01-2008, 03:56 PM
gridley51 is on a distinguished road
Brian,
it is normal for the brake to have voltage when the spindle is on.This voltage holds the brake off.When the spindle stops the power to the brake is cut off and the brake comes on.
Mark.
Old 03-01-2008, 04:04 PM
Thanks Mark
looks like a short some place or could it be a parameter.
I had to change one as it kept telling me the guard wasn't closed.
emailed beaver Mike. I have to post some answers to his questions Monday on the
Beaver going to Estop when trying to Ref.are you looking in to see the drawings for the turning job
Brian
BR
Old 03-01-2008, 05:37 PM
Brian,I thought you were going to fax a sketch.I`ll be at least another week before I`m up your way.Customer keeps coming with more parts,all wanted last week. :-)
Mark.
Old 03-06-2008, 07:09 PM
Unhappy series 1 interact mrk2 brake
anyone actualy worked on a Bridgeport brake ? or am I in the wrong section.
even a hint about the best way to check the circuit or what could be causing the power to stay on after the spindle has stopped. maybe a faulty on/off brake switch on the front of the machine or is there a contactor for the brake
the brake itself is working, its the signal to it thats the problem.
any advice would be a great help
BR
fanuc magnetic sensor keithmech Fanuc 11 05-04-2009 08:30 PM
morbidelli MAGNETIC dc servo michaeldriscoll Servo Motors and Drives 2 01-05-2008 03:28 PM
Need Help with Magnetic reversible Contactor Chris64 General Electronics Discussion 12 12-23-2007 03:54 PM
magnetic sensor keithmech General Electronics Discussion 0 07-28-2007 07:04 PM
magnetic clamping dhiruj Work Fixtures and Hold-Down Solutions 1 04-28-2007 03:37 PM
