Old 02-28-2008, 01:32 PM
Ted Gaul is on a distinguished road
EZ-Trak DX2 addlash?
I have Series 2 with a DX2 controller. When changing directions in the x or y axis there is a large jump(.009x, .025y). Is this a possible drive gain adjustment? There are three pots on the drive cards, but I am not sure what each of them are.
Thanks Much,
Ted
Old 02-28-2008, 02:31 PM
Moderator
machintek is on a distinguished road
At main screen, press the * key.
The code is 11235 follwed by ENTER twice.
Fix this file, putting in the proper values.
Update/save it.
Try it.
Do not mess with the drive potentiometers if you do not know what you are doing.
Do not shut the machine OFF in metric again.
George
Old 02-28-2008, 03:02 PM
Thanks George!
That looks like it solved it.
Should there be any values in the X & Y Offset.
Thanks Again,
Ted
Old 02-28-2008, 09:07 PM
Moderator
It will have values as soon as you set a part program zero.
George
Newbie- EZ TRAK SX jpboyt Bridgeport and Hardinge Mills 5 02-08-2008 12:19 PM
ez-trak rsbbmw Bridgeport and Hardinge Mills 6 06-07-2007 03:08 AM
Need help with EZ-Trak SX II Steve@Reliance Bridgeport and Hardinge Mills 13 09-26-2006 11:51 AM
EZ Trak II SX Steve@Reliance Bridgeport and Hardinge Mills 15 06-14-2006 02:04 PM
EZ-Trak Plus DWilliams123 Bridgeport and Hardinge Mills 2 04-28-2006 07:28 PM
