Well I've been running my R2V3 for a while. Most of the playing I've done have been just streight moves or segmented moves to make turns. Of course due to limited memory using arch moves is a good thing to save program space.. but for some reason and I yet to figure out my machine does not seem to do them right. In short when cutting the archs the turn ends up streighter then it should. Like the lower right turn on that part should be a circle but it cuts the corrner off in a shallow arc. I run the same code in mach on my other mill and it does not apear to cut the arch short. Please see the pics below and segment of Gcode I'm trying to run for my part. 1 pic of the part 1 pic of the plot of the part from NCPlot back plotter and the Gcode. Thanks for Any help to understand what is going on. 'Bridgeport' 'Cut StockPart no ramps' N4G70G75G40G17G90 N5G0X0.0Y0.0T12M6 N6S12000M3 N7G0Z0.7874 N8G0X0.1250Y1.1050Z0.0500 N9G1Z-0.0270F5.0 N10G1Y1.1055F10.0 N11X0.1244Y1.1173 N12G3X-0.6200Y1.7752I-0.7092J-0.0524 N13G3X-1.3644Y1.1173I-0.0352J-0.7103 N14G1X-1.3650Y1.1055 N15Y1.1050 N16Y0.5455 N17Y0.5450 N18X-1.3647Y0.5365 N19G3X-0.6200Y-0.1252I0.7095J0.0486 N20G3X0.1247Y0.5365I0.0352J0.7103 N21G1X0.1250Y0.5450 N22Y0.5455 N23Y1.1050 N24G1Z-0.0540F5.0 N25G1Y1.1055F10.0 N26X0.1244Y1.1173 N27G3X-0.6200Y1.7752I-0.7092J-0.0524 N28G3X-1.3644Y1.1173I-0.0352J-0.7103 N29G1X-1.3650Y1.1055 N30Y1.1050 N31Y0.5455 N32Y0.5450 N33X-1.3647Y0.5365 N34G3X-0.6200Y-0.1252I0.7095J0.0486 N35G3X0.1247Y0.5365I0.0352J0.7103 N36G1X0.1250Y0.5450 N37Y0.5455 N38Y1.1050 N39G1Z-0.0810F5.0 N40G1Y1.1055F10.0 N41X0.1244Y1.1173 N42G3X-0.6200Y1.7752I-0.7092J-0.0524 N43G3X-1.3644Y1.1173I-0.0352J-0.7103 N44G1X-1.3650Y1.1055 N45Y1.1050 N46Y0.5455 N47Y0.5450 N48X-1.3647Y0.5365 N49G3X-0.6200Y-0.1252I0.7095J0.0486 N50G3X0.1247Y0.5365I0.0352J0.7103 N51G1X0.1250Y0.5450 N52Y0.5455 N53Y1.1050 N54G1Z-0.1080F5.0 N55G1Y1.1055F10.0 N56X0.1244Y1.1173 N57G3X-0.6200Y1.7752I-0.7092J-0.0524 N58G3X-1.3644Y1.1173I-0.0352J-0.7103 N59G1X-1.3650Y1.1055 N60Y1.1050 N61Y0.5455 N62Y0.5450 N63X-1.3647Y0.5365 N64G3X-0.6200Y-0.1252I0.7095J0.0486 N65G3X0.1247Y0.5365I0.0352J0.7103 N66G1X0.1250Y0.5450 N67Y0.5455 N68Y1.1050 N69G1Z-0.1350F5.0 N70G1Y1.1055F10.0 N71X0.1244Y1.1173 N72G3X-0.6200Y1.7752I-0.7092J-0.0524 N73G3X-1.3644Y1.1173I-0.0352J-0.7103 N74G1X-1.3650Y1.1055 N75Y1.1050 N76Y0.5455 N77Y0.5450 N78X-1.3647Y0.5365 N79G3X-0.6200Y-0.1252I0.7095J0.0486 N80G3X0.1247Y0.5365I0.0352J0.7103 N81G1X0.1250Y0.5450 N82Y0.5455 N83Y1.1050 N84G0Z0.0500 N85G0Z0.7874 N86G0X0.0000Y0.0000 N87G0X0.0Y0.0M25 N88M02 |
Bob, I have a boss 8, I think your trouble is due to the bottom arcs coming in towards the center kind of like a rounded W (exagerated I know)What do you use for cad/cam software? If you are using Bobcad I have a post for that at home, I could send you a re-posted file tomorrow. I know the boss controls will accept radius command too. That saves a bit of precious space.You could try that. I think with the radius command you can do a 180 degree arc but I will check that when I get home. Is the geometry supposed to be continuous arcs? If so there is a problem there.I back plotted the cam file to bobcad and the arcs have different center points. Hope that helps cutmore |
| The Gcode produced from a post processor built up for Vcarve to make files for the bridgeport. I've played with the different parts of the post (that I understand) to get it working as good as it does now. But comming here because I'm still missing something but can't really blame vcarve or anything. b. |
| Just confused seeing when I open that Gcode in something like the NCPlot back plotter (like in the picture) the part paths look ok. If I output using the Mach arc's post the code is the same (with the exception of the header G's) and path looks right. so just confused I guess. and figured perhaps I was missing some header g command to put it in the right mode for this or something simple like that. b./ |
| For example perhaps I sould be in G74 multi quadrent circle input off rather then G75 circle input on. But don't really know what all that means. And not really clear in the manual but think 75 should be on or default. b. |
| Bob, I will check my settings when I get home. I am leaving work for the day. Try this file. Z zero to be the top of the material. :666 N2G0G17G30G40 N3G45G70G72G75 N4G90G96 T1M6S3000 M3 N6X0.125Y1.105Z0.5 N7G1X0.125Y1.105Z-0.02 F.5 N8X0.1244Y1.1173Z-0.02 F10. N9G0X0.1244Y1.1173Z-0.02 N10G3X-0.62Y1.7752Z-0.02R0.7112 N11G0X-0.62Y1.7752Z-0.02 N12G3X-1.3644Y1.1173Z-0.02R0.7111 N13G1X-1.365Y1.1055Z-0.02 N14X-1.365Y0.5455Z-0.02 N15X-1.3647Y0.5365Z-0.02 N16G3X-0.62Y-0.1252Z-0.02R0.7112 N17X0.1247Y0.5365Z-0.02R0.7112 N18G1X0.125Y0.545Z-0.02 N19X0.125Y1.105Z-0.02 N20G0X0.125Y1.105Z0.5 I will check back tomorrow, Cutmore |
| The G codes in the header I understand are G0= rapid, G17= x,y plane, G40= tool radius comp. cancel. G70= programming in inch, G75= something with the arcs( I forgot to look in the manual last night,Sorry) G90= programming in absolute coordinates. I will look up the rest, or if you have the manual you could look them up. I know every control can have different interpretations of a Gcode so the Boss8 & 10 could be different but I doubt it. Hope that helps, Cutmore |
| G75 I think was is full circle ability. Hum may have to do with end piont tollerance. can you post a drawing of your part with dims and origin? Just at a glance somthing looks off in the centers of the arcs to me. May be my eyes who knows |
#11
| The archs are as symetrical as they can be far as I know... I could post the vectors drawn.. The code given above gives an error message on the boss screen after the tool change. I altered it as one of the feed rates was .5 and that. But the error said something that sounded like it didn't understand one of the subscripts (I think it said) of course there isn't enough room on the screen to give a complete sentance error and of course I didn't copy it down. Far as the manual goes all the Gcodes in the header look like they would be acceptiable. And the manual does have R commands for circle interpolation. If I take my drawing and move it to have the part zero in the lower left corner of the part rather then lower right the squashed parts of the arch move to the other corners of the part. Just kinda fustrating seeing the same code runs an arch and path just fine under Mach. so maybe my machine is just showing it's age? I'd hate to think that because otherwise it runs everything else I do as good as I could ask. Maybe I'm missing something simple but have checked the programmer manual and stuff and think it should work. I agree that the centers of the arcs should be/could be the same since the part is symetric but I'm not seeing the squasing when I view it in the back plotter that I see when the part is run. Anywho. b. |
#12
| Bob, I just looked at the file I sent and this time I changed the 2 arcs to a single arc. Try this and let me know if this works. If so, then maybe it is something with the original file that the Boss just didn't want to do. :667 G0G17G30G40 G45G70G72G75 G90G96 T1M6 G0X0.125Y0.6198Z0.5 G1X0.125Y0.6198Z-0.02 F1. X0.125Y1.0302Z-0.02 F10. G3X-1.365Y1.0302Z-0.02R0.745 G1X-1.365Y0.6198Z-0.02 G3X0.125Y0.6198Z-0.02R0.745 G0X0.125Y0.6198Z0.5 Hope this helps, Cutmore |
| G2 and G3 Commands | Bohemund | G-Code Programing | 19 | 05-28-2007 10:12 AM |
| Difference between BL and SV commands? | Shizzlemah | Fadal | 3 | 03-23-2007 09:33 AM |
| Turbo CNC @ Arch cutting ??? | Milton | OpenSource Software | 0 | 08-14-2006 12:48 PM |
| Design & Cut Arch | krazycnc | General CAM Discussion | 3 | 08-26-2005 10:06 AM |
| EMC & the G28/G30 Home commands | Javelin276 | LinuxCNC (formerly EMC2) | 1 | 07-18-2005 04:13 PM |
