| Series II & Hilbilly BOB I have been working on changing my Series II over to one of Hillbillys Boards and can,t seem to get it working. I am running Mach3 on XP. I have triple checked my board wiring.I didn,t have to cut my original plugs off as I had part of an original wiring harness that had the plugs so I used them.I am glad of this because I had to go back to the Boss 6 control to do a machine job this weekend so I could just plug everything back in and run the mill. I just can,t track down the problem. I have added the 3 files to the macrofolder lke the instructions said plus set up the ports and pins as instructed. I dont get pin #10 input led to ever come on when I enable the mill and my software will still reset.The leds on the BOB will respond to an axis movement. Do you have to assign any motor pins while in Max cl mode? Probably something minor,I just cant put my finger on it. Anyone have a similar problem? I used 2 different pcs and still the same problem. |
| post this on the mach boards. hilbilly can probably help. archie =) =) =) |
| BOB Hillbilly has me on track now. He doesnt give up on a person,he has been great help,expecially when someone like me doesnt know much about the electronics end of this. |
| Wiring BOB I am attempting to track down mating plugs for the K5-K6-K8 on the XDI board. I don,t want to cut up my original wiring to add the BOB so I thought I would find mating plugs to wire from my BOB and plug into the K5-K6-K8 Would anyone know what I could use to plug into my Bridgeport wiring connectors? THANKS! |
| Check Digekey or allied electronics should be a standard electronic part what about posting a picture archie =) =) =)
| help series 5t | john-shipman@ho | Fanuc | 6 | 12-10-2007 06:23 PM |
| Charge pump for Hilbilly BOB | dougputt | Mach Software (ArtSoft software) | 2 | 10-11-2007 01:31 PM |
| Series II | Perp | Bridgeport and Hardinge Mills | 4 | 05-13-2007 12:50 PM |
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 09:04 AM |
