Old 02-21-2008, 12:51 PM
SPEEDRE is on a distinguished road
Set Up Definition
OK, just what is meant by "set up", when it pertains to a Bridgeport mill?. I can run one pretty good although I'm not a trained Machinist. I've run up against this description several time while searching for a job. Please explain the function of, " can you do set up " as well as operate?
Old 02-21-2008, 01:40 PM
big_mak is on a distinguished road
"Setup" will be can the forman give you a program, drawing material, tools, and a machine and let you get the machine up and running and prove off the first part.
I believe that's it in a condensed nutshell.
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 02-21-2008, 08:46 PM
Thanks Mak, thats just what I was looking for. I can do that.
What's the definition of an end mill? Swiss General Metalwork Discussion 2 07-31-2007 11:32 PM
Work Holder Definition MAX711 SprutCAM 0 12-13-2006 06:38 PM
MC V9 Casting Stock Definition CAMCRASH Mastercam 12 10-12-2006 04:52 PM
Tool definition David Da Costa Mini Lathe 0 07-04-2006 11:48 AM
Phase definition for SMC 800 controller Magnar TurboCNC 5 04-04-2006 08:17 AM
