Old 02-18-2008, 08:43 PM
watsonstudios is on a distinguished road
Question about Buying an older Bridgeport
Someday in the near future I would like to purchase an older Bridgeport and stay in the 2000 - 3000 price range. If the machine has worn ways or excessive backlash, is it possible to fix or re-build? Can the ways be replaced or re-surfaced? I don't know a lot about these mills so I don't know if this stuff is fixable. I'm guessing the leadscrews or whatever is used in the axis travel can be replaced but what if the ways are sloppy? Is it feasable to buy a cheaper mill and fix it or pay more for one that is tight and acceptable backlash?
Thanks,
Jon
Old 02-18-2008, 08:50 PM
holbieone's Avatar
holbieone is on a distinguished road
you can get a ball screw set for around $900.00
and the ways scrape for $750 to $2500(depending on wear)
if the machine is that worn i would not pay more then $1000
Buying and Using Older CAD/CAM Software bothunter General CAM Discussion 0 02-11-2008 11:59 PM
buying a cnc bridgeport BeeleJuice Bridgeport and Hardinge Mills 8 01-22-2007 06:16 AM
buying Bridgeport Interact 1 CNC Mill. ivan sandford Bridgeport and Hardinge Mills 11 01-13-2007 11:01 AM
Buying cutting tools in W. Canada (question to canadians) nagjames General Metalwork Discussion 11 07-08-2006 12:09 AM
bridgeport question rwerner518 Bridgeport and Hardinge Mills 6 05-17-2006 02:58 PM
