Old 02-07-2008, 12:18 PM
99bluemoon is on a distinguished road
BRIDGEPORT RAPID/FEED RATES OVERIDE
We have got a 1996 Bridgeport VMC 600 with Heidenhain TNC370 control.
Need to prevent the RAPID & FEEDRATE knobs from being altered.
There is no dedicated M Code to enable/disable this function so I assume it is controlled within the General User Parameters.
Feed Overide 999% Ceramic Man Haas Lathes 15 01-18-2008 09:13 AM
distance to go screeen? rapid overide? maranatha777 Mach Mill 0 03-19-2007 09:51 AM
Feed rates? Rainman229 G-Code Programing 3 02-23-2007 12:47 PM
Feed rates & IPM ChristopherWood WoodWorking 6 10-30-2006 04:08 PM
Feed Rate Overide problem Moondog Machines running Mach Software 0 06-14-2006 06:35 AM
