  #13   Ban this user!
Old 02-01-2008, 07:40 AM
bherr is on a distinguished road
Originally Posted by neilw20 View Post
The reference manual might be a generic USERS MANUAL.
When you can reference the machine, you will have made some progress.
It needs to know where it's extremeties are.
Gross error means it figures it unsafe to do anything practical.
It either thinks it stupidly huge, or tiny, or upside down.
It's a pity better documentation from machine builders stays in their 'secret' you'll never nedd this again file, (especially when I'm no longer in business)
Talk to a machine builder who knows your hardware if you get stuck for answers.
neil,
figured out the gross error problem by reading the manual and got that fixed, so now I can reference the axis. Now when I try and runa milling program I get a positioning error. I'm pretty sure I have the Actual vs the Reference vs the Dist points programmed wrong and the table isn't sure where it really is. I'm going to have to sit down with the Heidenhain manual today and try and figure out exactly what their telling me to do. these manuals leave a lot to be desired, if you know what I mean. thanks for the assistance.
ben
Old 02-01-2008, 07:53 AM
Moderator
machintek is on a distinguished road
If the zero was set in the wrong place and the movement commanded would exceed limits, it is possible this error may pop up.
The display (relative, actual, lag) has no bearing on this.
George
  #15   Ban this user!
Old 02-01-2008, 10:53 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question Program reference?
Ben,
A bit of persistance has got you over the first difficult hurdle! Well done!
What/where/which table do your programs use.
Single step a program you have run before and you will soon see where it shouldn't go, even if by memory (human type).
Are your tool change (and other custom) cycles still intact?
Neil
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Can Not get any movement from steppers. millman52 Machines running Mach Software 2 06-01-2009 06:23 AM
Jerky Movement elogicca Mach Mill 5 11-21-2007 08:19 PM
No Movement wishmasterg Mach Mill 3 02-14-2007 06:39 PM
No Movement of steppers help please rally.sport Machines running Mach Software 2 12-22-2006 09:05 AM
Axis Movement UKRobotics General Metal Working Machines 2 12-17-2004 01:33 PM
