I HAVE A 412 INTERACT WITH A TNC 2500 AND I HAVE MOVED THE MACHINE TO A DIFFERENT LOCATION AND WHEN I BOOT IT UP I AM GETTING A "SPINDLE DRIVE FAULT". I HAVE SWITCHED WIRES THINKING IT WAS A POLARITY ISSUE BUT NOTHING GOOD. THE MACHINE RAN FLAWLESS BEFORE I MOVED IT TO ANOTHER LOCATION. HELP NEEDED, PLEASE. THANK YOU |
| Check all connections by turning the power off and test tightening all screws, that's where I would start. Not only the main power conductors, there might also be some skinny wires going to a terminal strip on the drive, and some of those can be on a 'fault reset' type circuit. Gently pull on the wire at every crimped connection to make sure the crimp is holding good.
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 01:15 AM |
| "amplifier fault on axis" on fadal VMC 15 | siquedude | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 11-20-2007 06:11 PM |
| "Astrosyn Miniangle Stepper" Power Drive | hferraz | Stepper Motors and Drives | 0 | 10-31-2007 04:27 PM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 04:35 PM |
| "IRMCS2011" AC servo drive design platform / from International Rectifier | Chivo | Servo Motors and Drives | 4 | 05-17-2006 06:19 AM |
