Old 01-10-2008, 03:20 PM
biker_eh is on a distinguished road
Unhappy Communication issue with a EZ Track DX with Computer
Hello everyone! I hope some one maybe had the same issue I am having with transferring files. I am trying to send and receive files from a EZ Track DX to a PIII 450 PC running Windows 98. The Computer is setup with “EZ Cam” and “EZ Utilities V6.1” for sending and receiving the files text files (999.TXT). I have also been using the HyperTerminal Y Modem as well to transfer the files. Here is how I have it setup:
SETUP:
1.EZ TRACK DX running V.3.67 with a built in hard drive. I believe the internal computer is running DOS. The communication method is a RS232C 9pin D connector that plugs into a DB25 adapter. The wire configuration is normal for the adapter and the RS232C cable (Pin 2=RX, Pin 3=TX etc.).
2. PIII 450Mhz Windows 98 2nd edition with COM1 assigned to RS232C cable.
Baud Rate of 4800, bps Data 8, stop bits 2, Parity = None. A folder is setup on the C drive called “textfile” to put he .TXT files in.
Once both side are set up this is what I do to try and send a file.
Option 1:
a. Enter the “Utilities” on the EZ TRACK.
b. Enter “Receive / Send Files”
c. Select “EZ TEXT”
d. Select “Send other file”
e. It then displays a window to enter the file name.
f. I then go to the PC computer and open EX-UTLS.exe
g. I then make sure the baud rate is 4800 at 2 bits, then go to “Send file to EZ track”
h. A window opens up on the PC that says “ready to send file”.
i. I then go back to the EZ track and enter the file name, in this case
“999” for the file on the PC is called 999.txt that I put in the proper directory.
j. On the EZ track screen it displays” WAIT – Receiving File C:/TXTFILES/999.txt
k. BUT NOTHING HAPPENS and it times out!
The other way I try is the following:
Option 2:
l. Enter the “Utilities” on the EZ TRACK.
m. Enter “Receive / Send Files”
n. Select “Y Modem”
o. Select “Send other file”
p. It then displays a window to enter the file name.
q. I then go to the PC computer and “HyperTerminal.exe” and setup the com information the same as using the EX-Utls.exe program. I also tried 9600 Baud rate and setting the profile to Y Modem as options.
r. I then make sure the baud rate is 4800 at 2 bits, then go to “Send text file and select the 999.txt file”
s. Nothing really happens but the communication indicator is counting.
t. I then go back to the EZ track and enter the file name, in this case “999” for the file on the PC is called 999.txt that I put in the proper directory.
u. On the EZ track screen it displays” WAIT – Receiving File C:/TXTFILES/999.txt
v. BUT NOTHING HAPPENS and it times out!
Both the PC and EZ Track seem to see each other but the only thing I can think of is the directory that the EX track is looking at is it’s own and not the PC.
For example PC Directory: C:/txtfiles/999.txt (What I am trying to get)
EZ Link Directory: C:/txtfiles/999.txt (It’s looking at this one but not txt file exists.)
Two tricks I have heard but want more info first is trying to swapping pin 2=TX, and 3=RX. I don’t see how this would help since the pin configuration on the EZ link is the same as the RS232C protocol. The other option is an old computer for the simple reason that the RS232 ports from back then have a lower volt output. This one makes no scenes.
Any ways if any one has any ideas, links or company to talk to about this I would be very grateful! Thanks in advance.
-Biker_eh
Old 09-13-2008, 12:43 PM
Rock Dancer is on a distinguished road
-Biker_eh
Did you ever get this figured out? I am trying to do the same thing and get the same results you do. I am using a communication software called "DNC4U". This software works great on my Matsuura Yasnac I-80 for program transfer and drip feed but I cannot get it to work with the BP.
Rock Dancer
Old 09-13-2008, 06:42 PM
cnctools is on a distinguished road
Smile cnctools
Downloading programs is easy if they are small enough to fit into a 640 k block in Dos. I copy and past my progams in to windows 98 to the PGMFiles directory on the Machine. The machine I Am using is running Windows 98 in Dos mode. If they are larger than that DNC is used to run the program in segments.
Old 10-07-2008, 07:10 AM
rmcgraw351's Avatar
rmcgraw351 is on a distinguished road
communicating with eztrak
The best way that I have found to communicate between a desktop and the eztrak is to put a larger hard drive into the eztrak, install eztrak software and then install windows98, then set up a network between the bridgeport and the desk top pc. I have used this setup for 4 years now without problem. I also use ezcam. My machine is a 1995 dx 2axis with the EMI/ELROD 3rd axis add on, and the network card is built into the motherboard. I am running the bridgeport with win98se, and the desktop with winXP pro.
Old 10-26-2008, 07:43 AM
NC Cams is on a distinguished road
mcgraw351: how did you put in the larger HDD and NOT get into the problems with regard to the 504mb HDD size limit that the BMDC software supposedly has?
I'm suspecting that you partitioned the C drive to 504mb and then partitioned the rest of the drives as you saw fit. Right? Wrong? Please explain. OR did you leave the original DOM/HDD in place and just add another one.??
Would you mind sending a copy of your BMDCPRMS.SYS file? I"d like to see how they set the parameters for the Elrod system. I called ELrod and they didn't have the answer and referred me to EMI.
Every time I call EMI, all they want is my M/C or VISA card number. THings are tight now due to a health issue and I can't afford the luxury of EMI anymore.
EZ Track DX? Machinereaper1 Bridgeport and Hardinge Mills 16 09-21-2008 01:35 PM
General Computer Issue/Question NC Cams Computers and Networking 4 05-27-2006 01:07 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
Bridgeport EZ-TRACK DX2 zukes3140 Bridgeport and Hardinge Mills 10 12-17-2005 08:02 PM
fast computer as server, slow computer as terminal replicapro Computers and Networking 1 07-01-2004 02:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
