Results 1 to 9 of 9
Thread: bridgeport II interact II resistor source
    Sep 2007
    United states
    Looking for a source for a resistor thats on the breadboard of a bridgeport series II interact II heidenhain tnc151a labeled as ww 14w 5% 3r3 resistor Newark has them but they said since they are in the U.k. it will take 2 months to get them in there has to be another source for these any help will be greatly appreciated the newark part # is 26m4967 bridgeport II interact II resistor source-resistor.jpg
    Moderator
    Nov 2004
    try DIGIKEY.
    George
    Sep 2007
    United states
    Already tried they don't carry it. Thanks anyway
    Sep 2007
    Re ps supply parts
    Hi. Is this one of the components from the 24v power supply ? I am not near my machine but I did build an entire new power supply for my BP series 2 int 2 about 2 months ago. I was able to easily find all the parts needed, some had to be sub'd to equal value but all are working fine. Let me know If I can help.
    Sep 2007
    United states
    Dirky, that is probably something I'll have to do in the near future and probably pick your brain but my brother in law told me as long as the resitance value stays the same we can up the watts so if this is true there is some 25 watt in stock to get us up and going
    gus
    gus is offline
    Jan 2005
    us
    re
    more watts=good
    May 2004
    United Kingdom
    The wattage rating of a resistor is an upper value that mustn't be exceeded, no problems using a 25 watt in place of a 14 watt.
    Another approach is to use two lower powered resistors in parrallel - two 7 watt 6.6 ohm resistors are equivelent to one 3.3 ohm 14 watt one. As 6.6 is not a preferred value you would have to settle for a 6.8 pair giving 3.4 ohms rather than 3.3. Although this is outside of the +/- 5% tolerance I very much doubt it will give you any problems.
    AWEM
    Andrew Mawson
    East Sussex, UK
    Sep 2007
    United states
    Thanks for confirming Gus and for the follow up Andrew. I really enjoy this forum and for everyone taking time out of there day to help a fella out.
    Sep 2007
    resistor
    Yes....go ahead and increase the wattage....the package type will likely be of the heavy ceramic type....but they dissapate heat better and you do have the space for it. Just maintain the value (or VERY close) and you will be fine. when these things are built the bean counters trim all the designs down to the lowest cost for each component....sad when the higher wattage resistor will cost only pennies more.
    1. CNC Bridgeport II interact 4 Tnc 150
      By frenk59 in forum Bridgeport and Hardinge Mills
      Last Post: 08-06-2008, 08:49 AM
    2. Bridgeport Interact 316 VMC
      By L. Sakthivel in forum Bridgeport and Hardinge Mills
      Last Post: 05-05-2007, 10:07 AM
    3. What VDU for Bridgeport Interact Series1 ?
      By awemawson in forum Bridgeport and Hardinge Mills
      Last Post: 03-10-2007, 02:18 PM
    4. BRIDGEPORT Interact 1MK 2 CNC Mill
      By concrete guy in forum Bridgeport and Hardinge Mills
      Last Post: 01-22-2007, 06:54 AM
    5. Bridgeport Interact 1 MK2
      By Leyland 472 in forum Bridgeport and Hardinge Mills
      Last Post: 10-20-2006, 07:44 AM
