Old 01-06-2008, 09:08 AM
frog's Avatar
Dream outside the Box
frog is on a distinguished road
Boss/BobCad 21
I am having problems cutting circles ya just round circles, I am using version 21 I can do text perfect anything square, great when I get it to cut a circle it only cuts half of it, then stops, I have made sure in the setup I am using incremental and also selecting G91 to start, I had it work correctly a couple of times then when I went back the machine changed its mind and decided to do different. Can anyone help me setup my Boss5 with BobCad please? Awesome product they are very customer friendly however I believe that the tech service department is over loaded, I would appreciate it if someone could help me.
Old 01-06-2008, 10:03 AM
HuFlungDung's Avatar
Moderator
What does your sample code look like?
Some of those older cnc's could not cut a complete circle with one command, so the post processor needs to be set to output either 2 or 4 commands for a complete circle. 4 commands means one arc for every quadrant, and any controller will execute that.
You might also consider that switching back and forth between incremental and absolute can cause problems. Most would recommend that programming be done in absolute mode, and that the post processor be set to output arc end coordinates to match absolute mode and leave it alone when you get it working.
Reserve incremental programming for short subroutines.
Old 01-06-2008, 11:24 AM
cabledude is on a distinguished road
BOSS 5 requires G75
Hi Frog-
I agree with Hu regarding absolute coordinates. Out of the hundreds I've written for my BOSS 5 & 6, only a couple use incremental, and those can be problematic, especially if you have to stop the program midstream.
In order to get the BOSS 5 to do a circle using one line of G2 or G3 is to invoke G75 prior to the G2 or G3 lines. The manual says:
"G-75 Multi-Quadrant Circular Interpolation (restricted to XY plane)
G75 permits an arc of up to 360 degrees to be generated in a single block of input data without deceleration taking place at the quadrant cross over points."
I always use the absolute I & J coordinates as well.
Just use something like this:
N100G75G90
N140G0X1.000Y1.000Z.050
then some Z move, presumably
N160G2X1.000Y1.000I0J0F30
This will cut a (clockwise) circle starting at X 1.000, Y 1.000 with the center at X0 Y0. This example has the same start and finish point.
The F75 is modal, that is, once invoked, the machine will use it for all circle moves within the program.
Give the G75 a try and see if it works with your program.
Rob
Old 01-09-2008, 10:52 AM
frog's Avatar
BobCad 21 Boss5
I understand that there is a quadrant issue with the Boss 5, however the question that I have is this, I can cut text perfect and I do not have to do anything special, in the text I can cut circles, it works perfect, however when I go to doing a circle, a simple circle it goes nuts. I did try your suggestion I drew the circle in 4 quadrants then set the tool path as per four individual quadrants, and then there was a problem it cut an out of round circle, I did declare G75G90 at the start of the code, I am pulling out my hair.
Old 01-09-2008, 07:53 PM
Not sure what else to recommend, but...
Hi Frog-
First of all, I'm assuming that your Bobcad is feeding your G code into a box-stock BOSS 5. I have both a BOSS 5 and 6, and I have written hundreds of pgms for both. The biggest learning curve for me was learning how these machines think. Back in the early 80's (yeah, I'm old) I had a problem with an intricate part that required over a dozen intersecting radii. Machining this part for production justified the purchase of our first CNC machine. I spent many nights trying to figure out (using trig...remember that?) these points of intersection with no luck. The machine seemed to just go off on a tangent...literally. I finally gave up and called on a friend who worked at Bridgeport Machines (my shop is in Bridgeport). He put the drawing through his CAD system and gave me a punch tape (everybody uses those, right?) of the cutter path. The important thing I learned is that the finish point of a circle needs to be exactly the same as the starting point, to four decimal places. Even though the BOSS 5 steps at .001, it thinks (computes) to .0001. Even if not a full 360, you need to be accurate with your start point, end point and radius.
My point is, make sure you know exactly where your machine thinks it is (within .0001) when you call for a G2 or G3 move, and make sure the X & Y finish point you call out is identical (for a full 360). Don't try to put any Z moves into the line, either. Also, make sure your I and J are accurate to within .0001.
I have never had a problem with a simple circle, say starting at X1.000 Y0 I0 J0 and going 360. It's only when the circle starts at a point OTHER than the called out finish point.
As Hu previously pointed out, seeing your code might help us figure out what's going on.
I have a bunch of pgms that use cutter comp. If you think circles are fun, just wait 'til you try to add this to the mix! Fortunately, I use the machines for limited production, so once I get the program right, it's on cruise control. (until the drive transistors blow)
Keep us posted and although I still have my hair, I'm prematurely gray from the BOSS experience. :-)
Rob
Old 01-27-2008, 08:41 PM
frog's Avatar
Boss 5 Working Perfect
I finally did it, I was so surprised what it was, I have done serial development and would never have guessed in a million years what it was, I changed the comm setup from 7.e.1 to 8.e.1 that fixed the problem it now cuts complete uninterrupted circles machine works great, I would have never thought, due to the fact that it did text perfect, I did load with a port sniffer program, and when I used 8,e,1 it was great, when I used 7,e,1 it had some garbage in it, now I am off to the races. Thanks for all the help.
BOBCad Post for Boss 5 darrelp Tutorials 1 12-13-2007 09:51 PM
BobCad to Boss 5 darrelp Bridgeport and Hardinge Mills 13 05-24-2007 09:38 PM
Using bobcad with Boss control roni21702 BobCad-Cam 4 11-07-2005 10:40 PM
Bobcad and a Boss control roni21702 Bridgeport and Hardinge Mills 3 10-17-2005 08:05 AM
BobCad to boss 5 MrHorsepower General CAM Discussion 1 08-16-2005 07:48 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
