Old 12-28-2007, 07:05 PM
otpco is on a distinguished road
moog run for your life bridgeport !
Hi all converting a moog to ball screws and servoes so good so far but !!! need some imformation about the tool changer and the power draw bar . maybee a wireing diagram . ladder diagram . anything would be good . I am slowly working through the problems .I need some background to how it sequenced itself . any ideas . thanks to all otpco Australia
Old 12-31-2007, 10:46 AM
awemawson is on a distinguished road
curses curses curses. I had a Moog Hydrapoint 1000 with a tool changer a few years back. Had ALL the documentation - I had interfaced it to a PC using a parallel port to 32 way air valve interface that I built. Machine was scrapped, and I offered the manuals to all and everyone, no one wanted them so they went to scrap as well. I would far rather that they had found a good home
AWEM
Andrew Mawson
East Sussex, UK
Old 01-07-2008, 05:25 AM
flyeribe is on a distinguished road
moog
I also have not one but two moog 83-1000 right now one is beening converted as we speak with ballscrews left to do is change out some bearings in the head and mount the new related items and go. If I had a choice I be looking for more of them. As for the tool changer well we are not going to us it just yet. System is beening configure with servo 1100oz and viper drives with a candcnc items like mini-io card pendent and rely card software heading towards Linux emc2. I'll post some picture tonight.
Luke
They look like junk but I have a soft heart and think a moog needs a second chance.
Old 01-07-2008, 06:40 PM
moog hydra-point
Ok heres some from the start and then with new control panel
ID:	50088   Click image for larger version
ID:	50089   Click image for larger version
ID:	50090   Click image for larger version
Old 01-11-2008, 04:37 PM
Hi guys I ve posted some pictures in the Mach 3 Forum under moog take a look ! cant get it to post here . thanks mark
Old 01-12-2008, 09:35 AM
moog hydra-point
Ha Mark seen your pictures on mach3 yahoo group quite the looking machine you have gone along way with it. How did you do the quick draw bar you chop out alot of items there. I'm not going to do that just not yet as you see I'm still along ways away. Been trying to get my servo's and drivers going on the bench with not much luck. Thinking that what I have is not a command setup so I might be changing to something like Gecko's 340 or the new one that is coming out and then with a new controller card from Cnc4pc or a Campbells product. I going to start finshing the installation of my ballscrew and finish with mill head after that will see what kind of mood I'm in. I'll keep you posted.
Old 01-12-2008, 03:11 PM
moog !!!!
the power draw bar !! here is my solution . I took off the Hydrolic accuator and drilled a hole in the top using the cylinder put a threaded rod through and made a air cylinder for the top . it has only a piece of rubber in it . works ok . I think I will use a plc to run the tool changer and gearbox, drawbar side of the machine I run the drawbar etc manual doing the . changes with a few buttons email me offf line for more imformation Markoldfoster@aol.com I have some manuals on the way it will help me I hope .My machine has only a few hours on it .Like new !! the xyz works well all ball screws xy servoes and z twin steppers . more then happy so far
Old 08-21-2008, 04:20 AM
Rodger Kallu is on a distinguished road
Hi, have just joined CNCzone today. I have bought a Moog headgear to retrofit to another milling machine. I don't want control gear, just want the varispeed option and the ace spindle setup (large bearings). Have cut a lot of the now surplus framework/casting away but your photo takes my breath away, I didn't dare cut that much off. Anyway my real reason for posting is to find out how i can get back to 3MT in the spindle taper or a conversion arbor. I don't want to use the Moog taper tooling. Can anyone help plse. Also have a lot of early electric/pnuematic gizmos that are not much use to me as well as the entire moog drawbar. Rodger Kallu NZ
Old 08-21-2008, 10:44 AM
Moog run for lives
Welcome Roger you might have to go too a J head style with a R8 and have an adaptor R8 to MT3 like me you can find these items on ebay I bought one each for my mills by my picture you see that I installed the variable upper part of my moog plus I kept the spindle of the moog also, the only thing I have to do in finish my casting for the bellhousing for the new single phase 3 hp motor. And for others heres a up date to where I am at now going finish my patterns for the ballscrew mounts and both end pieces for the cradle install the other end of the ballscrew. In another picture you see what is two springs this doing on top of my spindle still need to put one of the air cylinders there and bingo a quick re less air applied and tooling falls out of spindle. Will have more picture later as we go.
Cheers Luke
ID:	65285   Click image for larger version
ID:	65286   Click image for larger version
ID:	65287   Click image for larger version
Old 08-21-2008, 07:31 PM
moog madness
good to see someone else has moog madness !! no known cure !!! my mill is still under construction but is working reasnably well . tool changer still being worked manual . carocell going auto . Mach doing a good job dont throw your old moog bits away . I might need some spares . I tryed the air ram thing on the draw bar there is a few drawbacks . cant get the dwawbar tight eneough . maybee Belview washers and air to release . I have now a 6inch bore cylinder to pull the draw bar up and streach the draw bar . it works well it is the fourth rethink of this bit the tooling has to be tight it was the lasr thing my tooling is erickson moog there own taper !! but I have a full set . keep up the good work mark sunny Australia
  #11   Ban this user!
Old 03-24-2010, 08:40 AM
Jim Blackwood is on a distinguished road
This thread is kinda old but I hope you guys are still around. I've had a Moog Hydraport mill for a few years now, very much like that red one. The iron was just too good to pass up. I stripped it down, cut down the head casting, mounted ballscrews and servos and I'm just about ready to look at servo drives. I've been running the mill manually, using pliers to tighten the gear nut on the drawbar and stacking blocks under the stop screw for the quill for depth, using a screw jack under the knee. I'm a little intimidated by the tool changer arm which I've disassembled and cleaned but haven't put back together yet. But I'm encouraged by your comments and the drawbar ideas give me hope. I never considered using a die spring and a pressure cylinder.
I still have to mount the quill servo and change pulleys to get the belt tight on the y axis, fairly minor stuff but I keep putting it off for one reason or another.
Well, like I said I hope you guys are still here. It'd be great to know some people using these old machines.
Jim
ID:	103570   Click image for larger version
ID:	103571   Click image for larger version
  #12   Ban this user!
Old 05-15-2010, 10:05 PM
CATCH22 is on a distinguished road
Smile
Just sent you a PM Rodger Kallu.
Moog Toolchanger WEDM Machine Problems, Solutions , Wireless DNC, serial port 3 02-26-2011 07:20 PM
DNC with Moog Hydrapoint III computerflummi Machine Problems, Solutions , Wireless DNC, serial port 6 03-19-2007 05:32 PM
Tip, low life Captain Midnigh CNC Plasma and Waterjet Machines 7 01-06-2007 01:26 AM
A life other than CNC. ynneb Australia, New Zealand Club house 6 11-22-2004 12:49 PM
Life without a PC duluthboat CNCzone Club House 5 11-07-2003 09:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
