Old 12-23-2007, 11:52 PM
arpieb is on a distinguished road
BP Series 1 Anilam > Mach conversion...?
I have a bid in on a private sale of a BP Series 1 machine whose Anilam controller and servos are still functioning, but the display is burned out. Sorry - I don't remember the version of Anilam controller (forgot to write it down), and the deal was too good to say no to in any case controller notwithstanding...
Assuming I acquire the machine - am I better off staying with the Anilam controller, or converting it to a newer Mach-based controller? What am I looking at having to change out if I go the Mach conversion route?
Thanks for any suggestions!
-R
Old 12-24-2007, 06:52 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Monitor
Hi arpieb,
If the machine has an Anilam 1100M series controller you may be in luck. One of the guys here on the forum had an Anilam 1100M Controller with with a weak monitor and did the following. This "may" work on other Anilam controllers.
He had a spare 17" VGA monitor (I think it was a flat screen). He just removed the plug in the computer cabinet that went from the VGA card and plugged in a VGA cable and hooked it up to the 17" VGA monitor. He may have made the connection in the Anilam Monitor Cabinet where the VGA cable plugs into the Anilam monitor. It accomplished 2 things. Got him a larger monitor that was easier to see and fixed his weak monitor.
The only downside as I see it is that you have to find a place to put the external monitor. One other thing was that I believe the monitor only displayed in monochrome due to the video card that is in the Anilam computer control box.
If you purchase the machine and it has the Anilam 1100M controller on it you can e-mail me at clarkj@tampabay.rr.com as I have some documentation, information and programs that will be very helpful in the use of that control.
Just some information that may be helpful.
John
P.S. I have a couple of Seiki XL 3 Axis Machines with Anilam 1100M Controllers on them that I am selling due to purchasing a HAAS TM-1P CNC Mill.
Old 12-24-2007, 09:42 AM
routerman is on a distinguished road
Probably better off going to Mach 3 because of the support. Does it have a tool changer ?
A lot of guys are using the Viper 200 drives on the big mill retrofits.
Old 12-24-2007, 10:24 AM
Andypcguy is on a distinguished road
PC Based Anilam
Those Anilam controllers are PC based so you can use a standard pc monitor in place of the old CRT. If the only problem your having with it is the monitor then you'll save yourself a bunch of money by staying with the anilam.
Anilam uses it's own proprietary conversational language and does not use Gcode so that could be a reason to switch if you didn't want to learn the Anilam control. I didn't like it at first but know I find it handy. Simple tasks like just drilling a bolt pattern or something...I can program it on the floor in just a few min.
Old 12-24-2007, 01:47 PM
kiwiavi is on a distinguished road
Anilam Mach3
Hi I have an old Anilam up and running and 2 new machines to convert. If it is an older machine, it has DC servo drives so Step and direction of Mach 3 will not work unless you get a converter card. The problem with older Anilam's is the CAM CNC software is limited.
I have personally been looking at EMC2 that can run Servo cards in the PC for the control. EMC has taken me quite a while to just get into it but if it all works as expected, I can use the existing servos, servo drive cards, power supply etc running with an onboard PC driver card.
Cheers Wallace
Happy Christmas.
Old 12-24-2007, 03:20 PM
uscra112 is on a distinguished road
Back when I was in the machine tool business I had to retrofit dozens of machines with the Anilam, because that's what the company was selling. I wouldn't give you a plugged nickel for one. Junk it and put a real control system on your machine.
Old 12-25-2007, 07:16 PM
cholder is on a distinguished road
If it is the 1100M, it has a convert from Gcode in the utilities menu. Also note that the I,J,K numbers need to be in absolute coordinates. I could see where if the display is the only problem, an external monitor would save considerable over a complete rework.
Old 12-26-2007, 10:17 PM
merl is on a distinguished road
I would stick with the Anilam controle if it is an 1100 or newer, Not to say that anything older is no good but, if you go much further back you will realy run in to support walls.
It does support G-code from the utilities menu and is fairly handy within its limits.
I'm not familler with the other operating system you refer to but, we did do a side by side comparasen of two identical machines several years ago. One had an Anilam 1100 and the other had the latest version of the Proto-Trak controle on it.
We simply found that while bothe were equelly suited the Anilam took more brain work to program than the Proto-Trak for the same job. This made it difficult to train newbees just out of tech school on the Anilam control.
I guess what I'm saying is the Anilam is a good unit but, it's not for dough heads.
If you would get into a Anilam 3300 or better you would see that it is a powerfull conversational controle that can do anything the big boys can do right there at the screen or off line ( I can program and operate my 3300 from home if I want to )
You do need to know somthing about machining procedures and program structure to make them operate efficently though.
Old 12-26-2007, 10:22 PM
Anilam 1100M
The Anilam 1100M control can also use the offline software that was designed for the 3300 control. I use it all the time and it is great.
John
Old 12-26-2007, 11:23 PM
Hey John That is cool!
I didn't know that but I am looking around kind of casualy for a two axis knee mill cnc for my own shop at home and that would certainly sway me.
Would that offline simulator also work on a Anilam 1100 Comando controler?
I know of a Devlieg 54K120 bar that has the Comando on it and may be coming up for sale.
  #11   Ban this user!
Old 12-26-2007, 11:46 PM
Off Line Software
Hi merl,
I am not familiar with that Anilam control. If you contract the person listed below he will give you the correct answer.
I would strongly urge you to shop for a 3 axis machine as it will increase your capabilities quite a bit. Working with a 2 axis control with no Z depth control is no fun. Control on the 3rd axis is a big deal.
Tim Podgwaite
Service Manager
Acu-Rite Companies, Inc.
716-661-1724
Hope this helps.
John
  #12   Ban this user!
Old 12-30-2007, 08:19 PM
JHCHOPPERS's Avatar
JHCHOPPERS is on a distinguished road
-R
I did a hardware upgrade from the 1100M to Mach3. I kept the servos, servo amplifiers and power supply. Added pixies and Mach3. The machine can now run at 200IPM, before with the 1100M it could only do 150IPM at best. This is a picture of the inside now that it is finished and running.
I am now adding a pendent and hopefully an ATC.
Anilam Crusader Series-M upgrade ? Fabric8r General CNC (Mill and Lathe) Control Software (NC) 31 03-15-2011 01:39 PM
Anilam Crusader ML Series Board R&B CNCzone Club House 1 11-05-2008 10:09 PM
Weight of BP Series 1 W/ Anilam Retrofit ? CNC OT Bridgeport and Hardinge Mills 1 02-16-2007 08:13 PM
Anilam Series-M (3 axis) to AjaxCNC anyone done that? efcattle AjaxCNC Control Products 3 07-28-2006 08:25 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
