Old 12-20-2007, 09:32 AM
bigtoad170 is on a distinguished road
Bridgeport series II interact II tool holders ?
I know this question has been asked before but it seems that there has been conflicting answers in the past threads. I have a bridgeport series II interact 2there is no drawbar I have the collett that you tighten with a spanner wrench to tighten the tool holder. So which taper is it bt30, nmtb30, or erickson quick change 30? I'm a newbie to CNC so forgive me if these are all the same thing I just want to be sure to get the right holders.
Old 12-20-2007, 01:03 PM
colin1544 is on a distinguished road
taper for series II
Hello need a bit more info but if the outside diameter of the quill is about 3.75" its 30 international, if it's 6.000" diameter then it's 40 international also this size will have a 4 HP motor the smaller 30 int will have a 2 HP motor both spindles are probably Bristol Erickson locking ring, hope this helps cheers Colin.
Old 12-20-2007, 01:31 PM
thanks Colin so I have a 30 international. I guess I'm still confused does this mean that a bt30, nmtb30, or a quick change 30 toolholder will work. Again i'm new at this
Old 12-20-2007, 04:38 PM
series II taper
Hello again I would more than likely say that you have a BT30 locking ring on your machine check to see if it has three Button head screws around the circumferance if so this a Bristol Erickson locking ring and takes the tooling with one flange for locking the tool into the spindle and two notches for the driving dogs on the spindle hope this sets your mind at rest, see if you can borrow a 30 int toolholder from someone to try it out. Cheers Colin
Old 12-21-2007, 06:19 AM
Yes!! thank you very much for your help. Hopefully I will be able to return the favor in the future.
Old 12-21-2007, 05:02 PM
gridley51 is on a distinguished road
Be aware that Int 30 is not the same as QC30.The flange of the QC is smaller in diameter and thicker than the Int30.
Hood who posts here sometimes has copy of the spec somewhere.
Mark.
Old 12-22-2007, 01:03 PM
Hood is on a distinguished road
The QC30's have a flange Dia of 46mm and flange thickness of 8.76mm.
The Int30's have a flange Dia of 50mm and flange thickness of 8mm.
Hood
Old 12-23-2007, 12:13 PM
Okay I found a holder that fits and seems to lock tight it has the dimensions for a qc-30 that hood provided. So one more dumb question is there anyway that the qc-30 be put in the 30 int spindle and feel okay but really is not fitting how it is suppose to. I'm assuming they could not because of the 4mm difference in the diameter but I hate to assume. Thanks for everyones patience
Old 12-23-2007, 01:34 PM
Not really sure what you are asking, but if your spindle has the Bristol Erickson QC nose on it so you will need to get yourself QC30 holders. It would be an easy task to turn or grind the 50mm Dia of the Int30 holders down to 46mm to fit in the B.E. nose but the important dimension on the QC30's is the 8.76mm thickness. As the Int30's only have 8mm thick flanges you wont be able to lock them into the taper. I have heard that some have adjusted the locking ring so that it can lock on thinner flanges but then they couldnt use the thicker QC30 ones unless they readjusted the ring. I tried this but couldnt get the ring adjusted enough to lock the turned down Int30 holders but maybe mine was just too worn?
Hood
Old 12-23-2007, 08:27 PM
Hood even though you weren't sure what I was asking for, you answered my question. I feel very confident that I have qc-30 tooling. Normally I'm not this incompetent but for some reason I confused myself and thankfully you were all there to bail me out Many thanks and happy holidays
  #11   Ban this user!
Old 12-24-2007, 10:16 AM
Dennis Storzek is on a distinguished road
You think you're confused… This stuff is made by Kennametal now, who is owned by (or owns) J&L Supply. If you go to the J&L web page at:
http://www.jlindustrial.com/Machines...ries/2083.html
and search on "Erickson QC 30" you'll find listings. But, if you click on the View Page icon, you'll see that in the print catalog they're listed as 30 NMTB, no mention of Erickson.
All is not lost, however. Look at the "Kennametal Tool Number" (not the J&L catalog number) All the old Erickson Quick Change stuff begins with either QC30, QC40, or QC50. You want the QC30 stuff.
I just bought a couple more double angle collet tool holders. I searched as above, then took the Kennametal numbers and searched on them in the MSC Supply online catalog:
http://www1.mscdirect.com
Turns out MSC now owns J&L, stocks all the Kennemetal tooling, and had better prices. Go figure. Problem is, searching for Erickson QC 30 on the MSC page wasn't finding them, and they also don't list the variety that takes the DA200 series collets I've standardized on. Going the route of finding the numbers in the J&L catalog and using them to search MSC brought up the listings.
Anyway, the tool holders that came were exactly the same as what I had, so I'm happy. What make some people unhappy is not being able to find cheap import knock-offs of this stuff.
  #12   Ban this user!
Old 12-24-2007, 11:03 AM
I guess I'm relieved that I'm not the only confused one out there.I would rather buy used than cheap knockoffs. Thanks Dennis for clearing up what I need to do for ordering through msc.
I was talking to one of my coworkers the other day, he said "that a place called michigan drill supplies those and they have quality tooling" http://www.michigandrill.com/ I never purchased anything from there but I probably take a look since I'm from Michigan and our economy is tumbling down quickly.
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 08:29 AM
Bridgeport Series II Interact 2 problems gugu Bridgeport and Hardinge Mills 24 01-10-2011 07:34 AM
Bridgeport Series 2 Interact 2 Transformer rrossey Bridgeport and Hardinge Mills 27 01-23-2007 07:09 AM
Bridgeport Series II Interact 4 & Heidenhein Problems UKRobotics Bridgeport and Hardinge Mills 10 04-03-2006 02:27 AM
Bridgeport series 1 Interact schematics Mike Conboy Bridgeport and Hardinge Mills 13 03-13-2006 09:32 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
