Old 12-16-2007, 07:03 PM
jshumer1 is on a distinguished road
bridgeport boss5 stepper to servo retrofit
Hello all, this is my first post in the zone. I have found tons and tons of info on this retrofit. (Thanks to all of you) This is my first retro to servo motors. Kind of a slow process for me. My dad started a small tool and die shop about 15 years ago outside our house in a barn he built. This boss 5 was the first cnc he bought, about 10 years ago. It’s always been a pain to keep it running. I spend more time trying to fix it then I do cutting on it. So I decided to bite the bullet, gut the sucker and start anew. Of course the servo motor will not fit with the same motor mounts. And I don’t want to mount the motor off the front of the machine. I want to mount the motor off to the side on a 45 degree angle or so. I was wondering if anyone already had prints to make up this mounting case. Any help would be much appreciated. I am very excited about finding the cnczone. A wealth of information at my fingertips.
Old 12-18-2007, 02:03 PM
Ok ok. Maybe I was asking a little much. My goodies from Camsoft should be here on Wednesday so I’ve started to design up the bracket to get this money maker back in business ASAP. I will post my pics as it develops.
Old 12-18-2007, 02:30 PM
mactec54 is on a distinguished road
Hi jshumer1
What motors are you using AC or DC I did my Boss 5 with AC servos and has been
great for 8 years now but I would mount the motors as they were mounted and
keep the 1 to 1 drive setup unless your motor is to long to go under the knee were
the old stepper motor was mounted
Mactec54
Old 12-19-2007, 07:05 AM
colin1544 is on a distinguished road
Boss 5 retrofit
Hello log onto AJAX CNC site they give you a full info for a retrofit on a Boss 5 machine dead easy. Cheers Colin
Old 12-19-2007, 07:48 AM
X and Y axis
Old 12-19-2007, 08:03 AM
I have been on ajacks, camsoft, you name it. I just wish I knew about this site earlier. My amplifiers, drivers and cables should be in today. (very excited) Anyways, I have designed my x and y axis cover and bracket. I cut the x-axis bracket last night. I am posting some pics, and some .pdf’s of the design. The pics are taken with my cell phone so I apologize for the poor quality. I will take better pics another time.
ID:	48835   Click image for larger version
Old 12-19-2007, 10:53 AM
Originally Posted by mactec54 View Post
Hi jshumer1
They are DC motors. I have a Shizuoka mill with a Bandit control that has never run. My dad bought it about 8-10 years ago, dumped a lot of money into it trying to get the control to work and renovating the machine. In the process had the servo motors rebuilt. I also have a Boss 3 Bridgeport with an Ah-ha control box. (Out of business) This one has worked great for years after I got rid of the control. I bought a package from Camsoft for everything but the motors. Should arrive today. After I’m through with the Boss 5, I plan to just break down and buy one of the bolt on controls for the Shizuoka. I just wanted to take the cheaper way first. Right now I’ve got all my eggs in one basket as the Boss 3 is my only mill running. The Shizuoka will be great to have running because the table travel is about double what I can do on the two series 1’s.
Old 12-20-2007, 02:40 AM
On my way
Ok, the z and x axis are mounted. I had to order some aluminum in order to cut my y axis bracket\housing. I also had to order a larger belt for the y axis in order to increase the center to center distance from 7.5 inches – 11.5 inches. This will allow me enough clearance to mount the motor back and off to the side, instead of out the front. A bit more work, but I think it will be worth it in the end. I have a few more pictures just because.
ID:	48912   Click image for larger version
Name:	x-axis mounted.jpg‎
ID:	48913   Click image for larger version
ID:	48914   Click image for larger version
Name:	z-axis mounted.jpg‎
Old 12-25-2007, 02:36 AM
Barry_ward's Avatar
Barry_ward is on a distinguished road
reverse motor mounts
Take a look at a few of the photos of my Shiz. IMHO the belt drive mount is the only way to go. I've seen a lot Shizoukas with the direct drive (motors in the way of your body) and I highly recommend spending the time and money to add the belt drives and get (at least the Y axis) motor out of your way.
With the motors sticking out, you ar bound to end up getting brused..
my projects:
http://www.barryfish.com
Old 12-29-2007, 05:21 PM
Finally finished the y-axis mount. Would have been done a day or so earlier except I did notice the bearing center was above the mount’s bolt pattern. DUMB screw up…. So I had to pocket it out, and machine up an insert with the bearing center in the right spot. I admit the mount and cover is a little elaborate, but I figured if I was going to do it, do it all the way. I think the lid is a nice touch.
ID:	49496   Click image for larger version
ID:	49497   Click image for larger version
ID:	49498   Click image for larger version
ID:	49500   Click image for larger version
ID:	49501   Click image for larger version
ID:	49502   Click image for larger version
  #11   Ban this user!
Old 12-30-2007, 11:03 AM
Barry_ward's Avatar
Holey Moley! FANTASTIC!
I assume that you have another CNC machine that you made these parts on.
Did you solid model them? If yes, what software? If no, how did you rough in the design?
Please detail the steps, tools, and feeds that you used to make one of the larger parts from solid. It would be very helpful to a uneducated, low experience hack such as myself.
Very cool. You really must have a good feel for shapes and how to turn them into reality.
best regards,
Barry
my projects:
  #12   Ban this user!
Old 12-31-2007, 02:54 AM
best regards,
Barry
Yes, solid model. I have used OneCNC for the past 4-5 years. Before that it was an out-dated SmartCam. (Not very smart) One CNC isn’t the best system out there, but you can’t beat the price. I machined all these parts on my Bridgeport Boss 3 with an Ah-ha control. As for speeds, and feeds, I roughed out with a ½” carbide end mill at about 15-20 ipm, and about 1600-1800 rpms. My spindle is manually controlled, so I typically write the code with the feed rate close to what I think I want. Then just manually override them to tweak the program. I am twenty-six years old and have been a Tool and Die Maker for about eight or so years. I was homeschooled most of my life and trained as a machinist/tool maker by my father growing up. Designing and machining parts is the easy part for me, but wiring this control and servo motors is a real pain. It’s coming along ok, but it has been a learning experience. Not sure if this helps Barry, or answers your question, but thanks for the compliment.
Servo/stepper size for Bridgeport w/ballscrews ? dfstrasser Bridgeport and Hardinge Mills 18 04-13-2007 09:03 AM
Bridgeport boss5 refit paulsoncd1@juno General Metal Working Machines 3 01-16-2007 05:46 PM
Mastercam X MACH 3 POST - Bridgeport Series 1 CNC (was BOSS5) bbuonomo Screen Layouts, Post Processors & Misc 4 12-31-2006 11:41 PM
Bridgeport Retrofit routerman Bridgeport and Hardinge Mills 5 03-16-2005 12:32 PM
Bridgeport Retrofit Using Brushless AC Servo Motors? Eric Servo Motors and Drives 6 12-05-2004 09:58 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
