Old 12-13-2007, 09:01 AM
colin1544 is on a distinguished road
Run a series 1 MK2 Bridgeprt cnc on a converter
Hello has nay one got any experience on running a Bridgeport series 1 Mk 11 CNC mill on a rotary three phase converter if so what size have you run it on and have you had problems or good results, or is it possible to seperate the control out using single phase to run the Heidenhain 155 control on single phase and the main spindle and coolant motors on an inverter I would be very interested in any comments. Thanks Colin
Old 12-16-2007, 10:02 PM
acerocket's Avatar
acerocket is on a distinguished road
My shop has 125V per line single phase and I hooked a Bridgeport Series I with Centroid controls (replaced Boss 3 controls) to a American Rotary Gentech 7.5 HP 3 phase convertor. So far it has worked just fine (about 3 months now). A few things I was told: Since my Centroid refit uses DC servos, I can get away with the 250V 3 phase. Also, it is possible to split off the computer and run it from 110 power, but I decided just to run it from the 3 phase since I don't program at the machine. It is a good idea to split off the computer in case you want to do intuitive or manual programming at the machine so you don't have to run the convertor all day. It is usually recomended to go at least twice the HP as your main motor (2 HP motor so a minimum 4 HP phase convertor for my machine) but I went with the 7.5 HP unit because of the 5% voltage balance up to 50% load. It does make a little noise but nothing intolerable. When running, I get 252V, 250V and 246V on the three phases.
I also run a Femco HL-25E Durga lathe (15 HP motor) with a seperate 30 HP convertor. However, for the lathe, it is not recommended to give the machine more than 230V (208V is the best) so I had to install a 24V buck/boost transformer in line before the convertor to cut the power to 232V 3 phase. When I run this machine, I get 232V, 231V and 221V on the three phases. Of course this convertor is a bit louder because of the larger 30 HP motor, but again, when the machine is running, you hardly notice the convertor.
A few things to be careful of are that you need to do if you use a convertor: follow the manufacturer's specs for wiring sizes when having your electrician install the convertor. My electrician thought he knew more than the Gentech people and he undersized the wires to the 30 HP convertor - so he had to buy me a new set of star capacitors, a new relay, and rewire the convertor back to the electrical panel after it blew up. Also, keep the convertors close to the electrical panel and the machine. They recommend no more than 10-15 ft from panel to convertor and convertor to machine.
Powerwise, they actually don't consume too much power when idling. I use 30-50 kWh a night to run my 4 2000 watt electric heaters, but can run both my machines all day with less than 15 kWh of power.
In case you want to check them out, here is where I got mine from: http://www.americanrotary.com/rotary...onverters.html
If you have any other questions, feel free to PM me.
Old 12-19-2007, 07:17 AM
Series 1 MK2 run on a rotary converter
Hello again thanks for the reply but the series 1 boss 3 machine you have is different to a MK2 as the MK2 has a 5KW DC spindle drive and no gear change which is alot heftier than a 2 HP standard 3 phase motor, but I spoke to a local supplier Drives Direct and he can supply a 10HP digital drive that gives balanced voltage surge control and can run other machines as well and does not need a pilot motor, the problem is the price £1750.00 (3500.00$) have to see if I can clear some old gear out to pay for it.
Cheers Colin
eps to dxf converter studysession Autodesk Software (Autocad, Inventor etc) 9 05-25-2009 05:32 AM
Rotary phase converter for Bridgeport 2J Series 1 KM-1 2HP setup? modernprecision Bridgeport and Hardinge Mills 12 07-01-2007 06:43 PM
help CAD CAM converter kiethnt General CAM Discussion 2 03-24-2007 09:29 AM
What is the Difference between 6000 series aluminium and 7000 series Kosta1234 General Material Machining Solutions 3 11-19-2005 08:04 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
