Old 12-06-2007, 09:25 PM
HimyKabibble is on a distinguished road
CNC Control Panel And Pendant Functions
I've just bought myself a lovely new Birmingham knee mill, which I will be immediately doing a 3-axis CNC conversion on. As part of the conversion, I want to build a nice control panel, which will house the computer display (LCD panel), keyboard, and a nice assortment of controls for common operations, and simple manual operations. If it makes sense, I'll also make a pendant, wireless if that has benefit. I'll be using Mach3 for the controller.
So, the question is: What functions does it make sense to put on the control panel and/or pendant. Some are, I think, obvious:
E-stop
Spindle speed/direction controls
Jog controls for all axes (joystick?)
Coolant on/off control?
What else should I include? Being an electrical engineer and a software guy, I have no problem with putting some "intelligence" in the control panel, if it's used to include some useful functionality.
I've never used a "real" CNC machine, just my self-converted X2 mini-mill, so I'd be interested in learning what kind of front panel functionality real CNC machines have as well.
Let's have some ideas!
Regards,
Ray L.
Old 12-08-2007, 12:45 PM
colin1544 is on a distinguished road
Birmingham knee mill conversion
Hello there for guidance log onto AJAX CNC site and look at there accessories they do a Hand held control panel and an MPG unit, this plus the keyboard should be all that you need. Cheers Colin
Old 07-26-2009, 02:16 PM
rppman is on a distinguished road
I am looking into buying a birmingham knee mill. Could you take a second and list some inforation about the mill. Quality? Thanks
Old 07-26-2009, 02:23 PM
I ment to say that when I get my mill I was looking into the control system from machmotion for $3500. You get the pc. Mach3 sortware.nice enclosure. And this comes with 3 stepper motor drive and control board all in the encloser. Then I was looking into the nema34 stepper motors. Their is also a deal on ebay right now that has everything you need to get going. Motors.control.pendent. for like $2300
Old 07-26-2009, 03:20 PM
Al_The_Man's Avatar
E-stop
Regards,
Ray L.
Because software based systems that use the parallel port are often I/O restricted compared to "real" CNC controllers, many functions are done on screen by touch or keyboard etc.
Controls that are not I/O starved have assets such as manual over ride switches for Feedrate, spindle speed over ride, feed hold etc.
Controlling many of these features by actual switch/push buttons tend to have a more positive real time feel to them.
For example, when rapiding or feeding into a part, it is nice to take the feedrate or rapid down to 0 and few % over ride, while monitoring distance-to-go to avoid a crash etc.
This is difficult with a screen slider O/R or similar.
This has always been my personal preference anyway.
Old 07-26-2009, 11:48 PM
I am completely satisfied with the quality. For the price, I think it is remarkable. If there is any benefit to a "real" Bridgeport, I don't know what it would be. This machine is very nicely made, powerful, smooth, quiet. I've had absolutely no problems with it. A friend of mine bought an identical machine a few months after I did, and he's had the same experience. I've CNC'd mine, and push it very hard, and it just keeps on tickin'....
Regards,
Ray L.
Old 07-27-2009, 06:59 PM
i am planning on doing the same to mine. was wandering, did you have to replace the ball screws for less backlash or are they pretty tight stock? also, do you use steppers or servo's? do you use pullies or direct drive mounts? i dont see too many companies offering mounting brackets. seems like everyone just makes their own.
Old 07-27-2009, 08:37 PM
It comes with leadscrews, not ballscrews. They're pretty good, but I don't think they'd last long in CNC duty. I replaced them with ballscrews and double nuts. I used servos from homeshopcnc.com, with home-made 2.5:1 belt reducers (there are pictures on CNCZone, somewhere....), though I will be increasing that to probably about 4:1, just to bring the top speed down to something safer. Right now, it'll do about 400 IPM wide-open, which is downright scary. I normally run 200 IPM rapids. I"m running the servos on Gecko G320s on a 70V/24A power supply.
Regards,
Ray L.
Old 07-27-2009, 08:57 PM
Thanks for the info. I am quite new to all of this. When or if you get time could you list where I should get the ball screws and nuts. I am planning on using 1200oz stepper motors. I have noticed from pictures on the web that when using servo's people use reduced gearing like you mentioned above about slowing them down. But most of the pics I have seen with steppers were set up with a 1:1 ratio or close to it. Is this just a personal preference or is the steppers just slower? Thank again
Old 07-27-2009, 09:03 PM
Servos run much higher RPM than steppers, and are basically constant torque, where steppers have high torque at low RPM, but torque falls off quickly with speed. So the reduction is a tradeoff between machining force, rapid speed, and resolution.
I got my screws and nuts from Nook - 1" XPR screws. Just go through their website, and you'll find them very helpful. You might also check with seller "linearbearings" on E-Bay. He has very nice screws, nuts, and bearing blocks at excellent prices. He'll also do custom end-machining on the screws (don't even think about doing this yourself on good screws like the XPRs....).
Regards
Ray L.
  #11   Ban this user!
Old 08-27-2009, 07:59 AM
I was wandering if the birmingham you bought had the china base or the tiwian base? I am looking at the china base but I am scared that it mike be junk. They said they are iso9002 certified.
  #12   Ban this user!
Old 08-27-2009, 09:14 AM
Mine is the 1649C, which is a Taiwanese head, Chinese base. I have no complaints whatsoever with any part of this machine. I think it is first-rate top to bottom. The only (minor) issue I have is a slightly loose fit between the spindle spline and the dog clutch, which causes a bit of rattle at times. But my impression is this is not unusual on BPs either.
Regards,
Ray L.
Anybody build a pendant/control panel with a PIC ? per.e PIC Programing / Design 1 05-10-2009 09:27 PM
stepper control boards and their functions cyclotron DIY-CNC Router Table Machines 3 03-02-2007 11:39 PM
My DIY control panel DennisCNC CNCzone Club House 6 10-02-2006 10:24 PM
Professional Control Panel Lables Karl_T General Metalwork Discussion 13 11-13-2005 04:28 PM
Building my control panel ChrisJ General Electronics Discussion 0 03-02-2005 08:09 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
