Old 11-05-2007, 12:50 PM
bherr is on a distinguished road
Question Strange problem ! BP II interact 4
Well I've got a strange problem that I haven't been able to figure out-Help Please. BP series II Interact 4 witha Contraves ADB/F 200 series 200 spindle controller, Bosch drives and Heidenhain TNC 155b. the other day while troubleshooting another problem I accidentally shorted out the 440V on the CPI board of the Contraves. this blew the Triresistor and one of the SCR's. I replaced them and now have spindle rotation, but another problem has happen. When powering up the machine I can reference all the axis and in manual mode I can do rapid movement and the handwheel also moves the 3 axis. When I go into the auto or step program mode the Spindle rotates and the X axis moves about a 1/4 inch and then stops. I get no error message on the TNC 155b and the flashing courser is not blinking. I've checked all the relays, tacho feedbacks to the TNC and the axis drives outputs and they all seem to be working. I've gone thru the schematics on the TNC, Contraves and the Heidenhain and can't determine what is causing this problem. when I'm in the step program mode I use to be able to switch to handwheel and move the 3 axis, but I can't seem to get into the handwheel mode, at least not all the time, were I use to be able to switch all the time. I've got the BP manual, Contraves and Heidenhain, but the schematics leave alot to be desired.
Can anyone point me in the right direction????
Thanks in advance.
ben
Old 11-05-2007, 08:29 PM
erd39030 is on a distinguished road
Just a post to follow this thread.
(I do have a BP Interact 412 with a TNC 151)
Old 11-05-2007, 09:43 PM
Moderator
machintek is on a distinguished road
is there any way to determine if the drive has tripped? Or perhaps is not turning as fast as it should? If the actual spindle speed differs from the command by 20 percent or more, it should go into a feed hold. There may be other damage from the power surge that will not make itself known through normal channels.
George
Old 11-06-2007, 06:34 AM
George
George,
I did notice that the spindle didn't seem to be turning as fast as it should. I've checked all the SCR's in the Contraves controller. My 440 v is normal, although I did notice that one leg was about 30 volts higher on the one leg. do you have any suggestions as to were to look for the problem. I just downloaded the Heidenhain service instructions so now I can troubleshoot that. I also am going to put LED's on all the DC relays and 110v lights on the ac relays to track if the relays are kicking in the way they should. there's a total of 20 DC and 7 AC relays. If the spindle isn't turning at called for RPM's. then I would assume the problem lies in the Contraves and that would make sense. I've checked all the fuses so I know they are good.
thanks,
ben
Old 11-06-2007, 07:19 AM
Moderator
If you provide me with your email address, I can scan and send you my contraves maintenance course notes (once I dig them up).
George
Old 11-06-2007, 08:01 AM
George
George,
Can't thank you enough! bherr@atlanticbb.net My machine has been down over two weeks.
Again, Thank You,
Ben Herr
Old 11-06-2007, 04:35 PM
BP problem
George,
OK here's some additional information that may be useful. the D107 light , which is the Current Limit light is on and shouldn't be. I tried reversing the spindle with a M04 and it did reverse, so that is good, however I measured the voltage on Pin #63 on the CPI board which is feed by the FRU bd. terminal #4 which is the +/- 10 volts for the armature. At full 3750 RPM programmed in the cycle I only get 7.3 vdc and with the RPM's adjusted down to 930 ( minimun permitted by the adjustable RPM adj. I get 1.9 vdc. I also noticed that D107 (Current Limit lite) goes out when the RPM's are adjusted below 1500 and the "F"(feed rate indicator) on the monitor is highlited over 1500 and not highlited under 1500 RPM's.
Ben
Old 11-06-2007, 06:28 PM
Moderator
Check your email.
The last time I worked on a contraves spindle drive was 20 years ago!
George
Old 11-07-2007, 11:31 PM
Big Daddy is on a distinguished road
I use to run those controls man its been 22 years ago! And I know my way around that machine inside & out! I just can't remember crap about the little jewel anymore. Sorry I wish I could help you guys!
Old 11-14-2007, 07:15 PM
Check your email.
George
George,
Thanks for the troubleshooting stuff. I finally manged to find the problem, which really was two items. when I shorted out the 440 it actually burned one of the connector pins which ran from the SCR's, so that was one of the problems. I decided to start tracing wires and circuit board connections, as some of the voltages were way out of line, but only when I exceeded 1500 RPM's. so using my OHM meter and the schematics I started checking all the connections,especially around the area were I shorted the voltage. Found a board line that was open and fixed that and now the machine is running the way it's supposed to. Still have the spindle shutting down during cycle runs, but feels this is a incoming voltage problem. I upgraded my electrical service to 200 amp and this has helped some, but still getting the same issue. I'm going to do some milling late at night to see if the problem lessens, due to lower power demand at midnight. If this proves successful I may then consider getting pricing on the electric company installing 3 phase power to the shop and if that is too expensive, which I think it will be I'm also looking into a PhaseTec voltage stabilizer. Well, so goes the battle. Again thanks for the help.
ben
  #11   Ban this user!
Old 08-28-2008, 12:07 AM
mostafa.bagheri is on a distinguished road
have problem
i have a huron machine with tnc 155 controler this machine doesnot use for 3 years and now i want to start it again baut i cant enable the spindle drive & i need electrical wiring for repair it
anybody have this cataloge for help to me
Old 08-28-2008, 09:48 AM
Moderator
To Ben.
Check the brushes on the spindle motor.
George
Interact 1 mk2 problem yarpo Bridgeport and Hardinge Mills 3 08-07-2007 01:12 PM
EZ-Trak DX strange wiring problem solved WagonWheel Bridgeport and Hardinge Mills 2 07-20-2007 08:21 PM
Strange G03 problem sploo Mach Mill 4 11-14-2006 05:24 PM
Bridgeport Interact 24v DC reg problem Paul_Leoni Bridgeport and Hardinge Mills 3 11-14-2006 03:15 AM
strange motor problem sp00k1e General Electronics Discussion 4 03-23-2004 05:46 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
