Old 10-31-2007, 04:55 PM
austin.mn is on a distinguished road
I need some parts for my Boss 3
I just bought an old Boss 3 series 1. it was retrofit with fagor controls at one time, then un-retrofit. however they never bothered putting it all back together. from what i can tell, i am missing the stepping motor pulleys for both the Y and Z axis and am missing the belt for the Y axis.
if you or anyone you know has these parts send me a pm with what you have. I would like to get this thing running by thanksgiving.
I plan on using some compumotor drives that i have laying around and run mach3 with a touchscreen computer.
i am also in need of Q/C30 collets.
thank you to any and all that respond.
Old 11-01-2007, 04:59 PM
nobody has any of these items?
come on guys, i know somebody out there has put servos on there machine and has some pulleys laying around...
Old 11-02-2007, 03:14 PM
Dennis Storzek is on a distinguished road
I think most servo conversions make use of the existing drive pulleys, I know mine did. Therefore no one has a spare set.
Dennis
Old 11-02-2007, 03:39 PM
unterhaus is on a distinguished road
I still need the 13 tooth pulley from the z axis for my mill. don't know why they had to use a small pulley like that, nobody sells one that small. And the stock ones break, so there probably is a shortage. I've thought about using a 26 tooth instead, but getting the belt around the spindle looks like a real trick.
I think you should be able to buy the y axis pulley from an industrial supply house, it's a standard pulley.
Old 11-09-2007, 10:53 AM
does anyone have the stock specs or know where i can look them up for the pulleys? If I had that info then at least i could find some to order.
My Z axis looks like it will take a much larger pulley than a 13 tooth. so maybe they had different pulleys for different years.
i haven't found much on the web as far as parts lists or diagrams/manuals for the boss series mills at all. does anyone know where i could run across anything like that?
Old 11-09-2007, 06:44 PM
Kevin Taylor is on a distinguished road
Boss 3
Austen Min. I have a pristeen Boss3 I haven't used much since I took possion of it and I know someone who has a coupple of hanger quines to rob part's from The Qc30 stuff showes up on ebay just search tooling and Eq. for BPT and try seller name BPTRS I think he has a lot of stuff that came out of the factory I will check if my frend has any extra part's Good luck Kevin
Old 11-09-2007, 07:26 PM
thanks kevin, i would really like to get this thing operational and any help at all would be greatly appreciated. even if nobody had anything that they wanted to sell, if i could find out the pulley sizes so i could order something would be great.
i was able to find a site that showed the disassembly of a boss 3 head, with a comparison of a standard j head. it looks like i will probably just have to make a draw bar since the spindle length is a bit longer, not to mention that the nmtb30 collets have a different thread pitch than the R8.
Old 11-09-2007, 09:39 PM
some of the heads apparently used a 26 tooth pulley. You have to count the teeth on your x and y pulleys, you want either a 2:1 or 1:1 ratio. My x and y turned out to be H series 1/2" pitch 14 tooth pulleys like the 6495K611 from McMaster Carr
go to: http://www.mcmaster.com/ put that part number in the search, and go to the catalog page. You need to get a bushing
Old 11-09-2007, 09:54 PM
thanks Unterhaus!
I just looked at the mcmaster chart and it looks like the 26 tooth is probably what my machine had on the Z (4.39" diameter) i will have to double check that dimension with the scratch marks on the machine.
then i will just measure the distance center to center on the Y axis shafts (motor and leadscrew) and get the belt length.
thanks again for the help.
anyone know if somebody has already made a drawbar for using nmtb collets in the Q/C 30 spindle?
Old 11-10-2007, 07:58 AM
Eric is on a distinguished road
Both of my Boss 4 and 5 machines use 26 tooth pulleys.
  #11   Ban this user!
Old 11-10-2007, 11:32 AM
Boss 3
Austin Mn. I will try to contact my frend on monday he has done a couple of conversion's on early Boss's and has a pallet of leftover's I don't think it is practical to do the R8 conversion but you can do a E30 holder with collect's
My Boss3 is for sale with tooling and has a com box to rs232 wich they dont have it's a creampuff came out of a university med lab and is realy nice I need room so we should talk 712-527-4625 ktaylor253@earthlink.net
I will try monday to find out about part's Kevin
  #12   Ban this user!
Old 11-12-2007, 09:43 AM
I think mine may have originally taken a 26 tooth pulley, except the belt is too small for that. But the way the belt runs it seems to rub a bolt head. How hard is it to change the belt? Looks like a lot of work.
I bought it without any motors or pulleys, I'm reverse engineering it.
Homing boss 8 or boss 10 wcarrothers1 Bridgeport and Hardinge Mills 9 06-05-2008 08:06 AM
Where to buy BOSS 5 Hard Parts? braidmeister Bridgeport and Hardinge Mills 13 01-31-2007 05:26 AM
BOSS 5 Replacement Parts & ?s braidmeister Bridgeport and Hardinge Mills 4 05-30-2006 10:36 PM
Bridgeport Boss 3 parts for sale chrispy Bridgeport and Hardinge Mills 2 04-14-2006 08:09 PM
Boss 9 Boss 10 parts swop Drewboy Bridgeport and Hardinge Mills 1 03-29-2006 10:16 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
