Old 10-22-2007, 01:47 PM
5S Dude is on a distinguished road
Trouble lifting and lowering the knee
Are there any additional grease fitting or lubrication points on the “Elevating Screw” for a V2XT CNC Mill?
Thanks guys.
Old 10-22-2007, 02:24 PM
gus gus is offline
gus is on a distinguished road
re
I would be betting on gibs over screw if it is binding
Old 10-22-2007, 02:54 PM
Thanks gus! There are what appears to be two small lock handles on the rear portion of the knee and I thought they were loose but I will check them out. Are there any other lube points besides the grease fittings.
Old 10-26-2007, 11:09 PM
NEATman is on a distinguished road
5S Dude-
If you find any additional lube points, let me know, as I've had an intermittend stick/slip condition when I lower the knee on my V2XT. It sticks, then drops - like a steady thump, thump, thump... Not good! It dosen't tend to do that when I crank it very slowly, only when I try to move it at a decent "knee handle cranking speed".
The vertical dovetails on my machine are well lubed as well, it has a one shot system, and the exposed dovetail shows a fresh oil film when I crank the knee up and down.
NEATman
Old 10-28-2007, 07:08 PM
Thumbs up "Sticking Knee"
Originally Posted by NEATman View Post
5S Dude-
NEATman
Hi NEATman,
I did remove the three ¼-20 Allen bolts and remove the “Crank Shaft” and applied waterproof wheel bearing grease to the pinions and vertical jack screw through this access point. Once I removed the shaft it is easy to see into the knee casting. You can even lube the y-axis ball screw from this access point as well if the one shot poops out. Our mill also has a Bijur one shot lubrication pump located at the rear of the machine and in addition I have always made it a habit to squirt vactra 2 on the moving parts. We mainly use flood water soluble coolant on everything except tapping cycles and our machine typically runs on Saturdays only. Our knee started doing the same exact movement you described and Gus told me to check the two locking gibbs located at the locking levers where the knee mounts to the main body. They seemed to be working fine and I have started to think it may have something to do with the locking lever located just below the crank handle. I’ll have to fiddle around with it more when we return from the SEMA show next Saturday. Sorry for the dirty machine and that I couldn’t be of more help. I’ll try and add some photos of today’s tinkering. Have a great weekend.
Name:	hole entrance.JPG‎
ID:	45948   Click image for larger version
Name:	Hole Face.JPG‎
ID:	45949   Click image for larger version
Name:	looking into hole.JPG‎
ID:	45950   Click image for larger version
Name:	Side of Knee.JPG‎
Name:	crank parts.JPG‎
Old 10-28-2007, 07:48 PM
handlewanker is on a distinguished road
Hi Dude, many years ago I had the same problem with a horizontal mill I worked on.
It got so bad that when you wound the table down it wouldn't move for the first turn of the handle, then a big thumpity thump as you continued winding down.
The boss got worried about it and had the machine stripped down and the knee removed to check.
The problem was caused by old lubricant, that had mixed with coolant trapped in the knee slideway and had decomposed to form a gummy varnish like coating on the slides and jibs, and caused so much stickiness that the weight of the knee was insufficient to overcome it, acted like a brake.
After a good clean up, no scraping required just degrease and relube, it was as smooth as new.
Oil does dry out, and the presence of water will also emulsify it and in addition there will be some corrosion that will make the surfaces rough.
The presence of rust between the slideway surfaces is in the form of a raised coating, and no amount of added lubrication will overcome it.
One of the big problems with sliding metal on metal slideways is if there is insufficient movement on a regular basis, then corrosion WILL take place.
A while back there was a big discussion on this forum with someone with a knee on a Bridgeport that had frozen solid and needed dynamite to move it.
It's a massive job to dissasemble the knee from a mill, to just clean it out, but if it's not done then the slide ways will get corroded.
Needs some very heavy lifting tackle, unless you take the table and crosslide off first, big job.
Ian.
Old 10-28-2007, 09:48 PM
chich2 is on a distinguished road
How about try a high detergent oil through it for a while? This will break down any varnish quite quickly.
Chich
Old 10-29-2007, 08:57 AM
Thumbs up Sticky knee
Boy! I’d hate to have to take the table and knee unit off the machine to clean the vertical ways. By looking at them they do not appear to have any corrosion present. I will look into high detergent oil and some sort of degreaser to see if this helps. This forum and you folks are quite simply awesome. Thank you so much for your input.
Old 10-29-2007, 03:06 PM
NC Cams is on a distinguished road
First of all "detergent" oil contains disperants which HOLD stuff in suspension/solution do that it is flushed out when the oil is changed. It is not a "washing detergent" per se.
Moreover, part of the additive package that is a part of "detergent oil" (namely the zinc anti wear additives) literally etch and plate themselves to the iron/steel particles. Depending on the metal, this can be detrimental to the integrity of the parts, especially if it mixes with water and/or cutting fluids. More on this later
Coked/caked and/or dried out lube is nasty stuff that needs an appropriate solvent to break up/down in order to re-liquify it - "detergent oil" may not be that solvent.
Some solvents to consider would be WD-40, othe "penetrating oils" and perhaps Dexron. These all have demonstrated a capability to disolve and/or penetrate oxydized lubes - they may not work with concrete solid caked on lube but may/should work better than "detergent" oils.
Guys have used various home brew concoctions to disolve tired/caked/oxydized grease. You really need to be careful both from a health/safety standpoint as well as from a compatibility standpoint.
Reason: the BPT's uses bronze gears and bushings and ball nuts. These can readily be attacked by the additives in some lubricants - the Zinc anti wear agent in "motor oil", expecially "detergent" oil is not particularly friendly to some bronzes - Why? Zinc bonds with and attacks the copper in bronze causing it to break down and lose structural integrity.
Dexron, however, if formulated to be bronze friendly - Why? Because a lot of tranny thrust washers are bronze based and the lube/additive formulation is made in such a way to NOT be agressive toward white or cuprous metal bearings. A simple tranny fluid change has been known to unstick gummed up valve bodies in auto transmissions - it may do the same for solidified grease on the knee.
A trick that can be used for gummed up hydraulic valve lifters is to give the engine a dose of couple of quarts of Dexron along with the regular oil - allow to idle for 10 min or so and drain while the oil is HOT - DO NOT DRIVE.
I've seen where this trick will quite down gummed up lifters and even free up stuck/gummed up oil rings. You do NOT want to run it straight as it does not have the anti-wear additives that are needed for non-roller tappets. This is why you have to dilute it with "real" motor oil. The commercial "motor flushes" may be helpful in disolving gummed up varnish and lube as that's what they are designed to do/meant for.
Talk about real "detergent" package, motor flush is it....
Old 10-29-2007, 07:46 PM
Thanks for the info NC Cams. Sorry for the bum steer I guess. The reason I stated this is due to a problem we had in a 3 stage turbo compressor at work. Beautiful machine. It's an air compressor that produces 5000 cu/ft a minute at around 800kpa (120psi) 1st stage is approx 9" dia spinning at 25,000 rpm and stage 2 and 3 are progressively smaller both spinning at 36,000 rpm. Any way the gear train and hydrostatic bearings got deposited with a varnish or shelac all over the gears and shaft. It was recomended by the manufactruer to run a "high detergent oil" to remove this gunk. But going from your information it looks like the oil recomended by the manufacturer to do this with probably contained something else in it that did the actual cleaning. The "Detergent" may have been a figure of speach?
Thanks for the info,
Chich
  #11   Ban this user!
Old 10-30-2007, 09:48 AM
Wow!
Thanks for all of the ideas everyone! It sounds as if I have a bit of work to do on my machine. Luckily, the knee is the only axis that has this problem. I'll try cranking it to it's extremes of travel, and cleaning the exposed dovetail areas that I can see on the base, and perhaps that will reduce the problem.
Otherwise, I guess I'll need to pull the knee off, and get it clean. I'll be sure to clean out all of the one shot lines and orifices when I'm in there. I've been meaning to purchase a 2 ton shop crane for a while now. This will be one of the first tasks for it.
I've also been wanting to measure the underside of the knee and the knee screw for a while now, as I have what I think is an original idea on retrofitting a knee mill to drive the knee.
NEATman
  #12   Ban this user!
Old 12-05-2007, 01:35 PM
cut more is on a distinguished road
Stick slip on the knee
Hi guys,
We have a manual bridgeport at work that has the same issue when lowering the knee. I have found on that mill, if you tighten the knee lock the stick slip goes away. This is not the cure, merely I think an indication of the knee gibs on this machine needing to be re adjusted. Any one else agree or dis -agree?
Maybe a couple others with this problem could try it and see if you get the same results.
I had to tighten the lock snug not cranked down.
Cutmore
z axes lifting John Teichman Mach Mill 6 02-10-2008 09:12 PM
Heavy vice lifting Pat2000 Safety Zone 26 03-16-2007 12:10 PM
Lowering a PCNC 1100 thru a Hatchway dkaustin Tormach PCNC 7 10-28-2006 03:26 PM
Lowering PS Voltage id 10 t General Electronics Discussion 3 12-13-2005 01:51 AM
Lowering Voltage on Power Supplies? DaSigntist General Electronics Discussion 2 01-17-2004 02:31 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
