Old 10-18-2007, 05:52 PM
UKRobotics is on a distinguished road
Spindle Reverse on a Bridgeport Interact?
I'm doing an electronics retrofit on a bridgeport interact and I'm wondering how important it is to have the option to reverse the spindle direction?
Am I likley to need it much or even ever ? The only two cnc machines I have used previously had no such option.
Basically if theres a chance I might need it later I'd rather do it now so I can design it properly rather than bodging an add on at a later date. That said, if it's unlikley i'd need it i'd rather save mysef some time/space/money and remove that part from my design entirely.
Another question on the same subject .. the motor in my machine is a 400v DC series/shunt wound motor. Is it possible to reverse the motor direction by swapping the polarity of the field voltage or will this only work with the armature?
If I can get away with the former that is much lower voltage and current so I could get away with cheap relays rather than vastly expensive contactors.
Dom
http://www.ukrobotics.com/projects
Old 10-18-2007, 07:50 PM
gus gus is offline
gus is on a distinguished road
On back gear it is required to go forward in back gear, if you have them
Reversing is nowhere near that simple, not even close
Old 10-18-2007, 08:55 PM
Al_The_Man's Avatar
The direction can be changed by swapping the field if need be, in series mode or shunt, I assume it is use in shunt mode?
Old 10-19-2007, 03:48 AM
Forgive my ignorance but what is the difference between series and shunt?
Gus: there are no gears or anything like that. Reversing has always been done electronically through the speed control.
Dom
Old 10-19-2007, 08:51 AM
gus gus is offline
The control has safeties and such to stop it reversing at 3000 rpm. I can't imagine any other dc controller would not have reversing built in.
If you ever wanted to tap, which is handy, you would need to reverse, otherwise I have never used it on my knee mills
Old 10-19-2007, 03:37 PM
gridley51 is on a distinguished road
Don`t know what you mean by safties Gus but any decent spindle drive can reverse a motor at 3000 rpm.It is not done by changing direction at 3000 rpm but by taking the speed down to zero and back up again all under control and extremely quickly.
I have 80 hp dc lathe spindle motors than can reverse from 3000 revs in under 4 seconds.
I`m not sure if the OP understands how dc drives work or if he is trying to save money but if he plans on reversing the polarity of dc motors under load with relays or contactors he`s gonna get a surprise.
With a dc drive on analogue control you would just reverse the polarity of the 0-10v ref.voltage.
On edit.That would only apply to four quadrant drives.
Old 10-19-2007, 03:49 PM
gus gus is offline
>>I`m not sure if the OP understands how dc drives work or if he is trying to save money but if he plans on reversing the polarity of dc motors under load with relays or contactors he`s gonna get a surprise.<<
Exactly my point. MY 1942 EE had it figured out, but people keep needing to reinvent the wheel....
Old 10-19-2007, 04:01 PM
Gus,what`s a 1942 EE?
Mark.
Old 10-19-2007, 07:09 PM
The drive I have purchased is a 2 Quadrant controller so it does not have the facility to reverse. I've been told the only way to have a reverse spindle feature is by using relays or contactors.
Ovbiously I'm not going to attempt to swap the polarity when the motor is going at full tilt (or even turning at all). Should be easy enough to tell mach3 not to allow such a condition.
Can I cut threads without reverse? i.e. using a thread cutter rather than a tap.
Also will it harm my motor to leave the field energised without the armature for long preiods ?
Dom
Old 10-19-2007, 07:57 PM
gus gus is offline
why bother with such a low tech device?
is the original doa?
  #11   Ban this user!
Old 10-20-2007, 02:39 AM
Robotics,sorry about doubting your knowledge od dc motors but when you asked about reversing it I thought that you were going to treat it like an ac motor.
You can reverse a single quadrant drive by reversing the motor armature leads with a pair of interlocked contactors.Use the zero speed signal from the drive as an interlock so it can`t happen at speed.
As Gus says it`s not really a step forward doing it this way.I personally wouldn`t bother going to the bother of fitting reversing contactors to this drive as you`re not going to gain anything.Fit the drive as it is and if you pick up a reversing drive in the future it`s an easy changeover as the wiring is already in place.
Is this a Mentor drive that was on Ebay recently?
I have bought a few Mentor and Eurotherm drives of Ebay but only buy four quadrant ones.With the Mentor you have to check the serial number for an R in it as all the Mentors have a reverse led on the front whether they reverse or not so some sellers advertise them as reversing.
It will not harm the motor to leave the field energised for long periods,I have machines wired that way from the factory,it keeps the windings dry.Some drives like to cut the field power back when the drive is at standstill.Your field will of course be controlled and monitored through the drive.
Mark.
  #12   Ban this user!
Old 10-20-2007, 03:42 AM
Gridley: Don't worry about it, no offence taken.
Ok, a bit more info for you:
When i bought the machine it came with an all singing all dancing contraves drive worth about Ł3k. Unforuntatly someone had let out the magical blue smoke before I got hold of it and the cheapest quote I got for repair was not under Ł1,000. (Someone had also let the blue smoke out the heidenhein but that is another story for another time) But lets just say there was enough wrong with the machine when I bought it to make retrofitting with my own mach/rutex control system the best option.
Unsure of the best way to proceed, I removed the spindle motor from the machine and took it to a local company which specalised in DC motor repairs, re-winds and controls. They took a look at the motor, realised it was in quite a state and did quite a lot of work on it including skimming/undercutting the comm, replacing the brushes, spindle bearings, taco brushes and cleaning out the carbon dust as well as converting the blower motor to single phase (I have no 3phase in my shop)
Once this was done they set about finding me a way of running the motor with cnc control from a single phase supply without breaking the bank.
Their solution was a 5kw autotransformer (240v - 415v) which supplies power to a Eurotherm 512C drive.
This is quite a simple DC drive and only provides control for the armature. The field windings must be powered and controlled separately. My advice from the company supplying me with this kit was to use a small variac (which they also supplied) which I could then use to 'tune' the voltage going to the field to find the best compromise between speed and torque.
The controller has all the normal things such as accel/decel ramps as well as tacho input for closed loop operation, and a 0-10v analouge input which will work with the CNC4pc speed control board. Having considered your suggestion of a zero speed hardware interlock, looking at the manual here reveals that it has a 24v digital output to indicate zerospeed condition so I guess I could use that without too much trouble.
To be honest I'm a little concerned about the number of comments which seem to be suggesting what I am doing is a bad idea. Should I carry on as I have started (considering I have already bought all the parts) or would I be better off looking for a different spindle control?
Bear in mind I am a uni student with no money and this is all having to be done on a rather tight budget. I think this control cost me in the region of Ł150 so the very most I could afford would be another Ł150 on top of that to get something better. Are their any controls in the <300 range which will control both field and armature and offer reverse? or even just reverse and armature control ?
Dom
bridgeport interact 4 spindle drive 0041601 Bridgeport and Hardinge Mills 34 02-09-2012 03:33 PM
Spindle Forward/Reverse = High/Low change AdyAstley Machines running Mach Software 2 06-06-2007 09:33 PM
reverse spindle problem bala955 Fanuc 1 03-08-2007 05:24 PM
Spindle sticking in reverse creep_pea Bridgeport and Hardinge Mills 3 10-02-2006 10:48 AM
Identifying Bridgeport Series 2 Interact 4 Spindle Motor UKRobotics Bridgeport and Hardinge Mills 2 05-26-2006 06:55 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
