Old 10-08-2007, 11:19 AM
dbcooper99 is on a distinguished road
Series I with Heidenhain 155 Won't run program
Hello everybody. I just purchased a series I with a TNC 155 control. I can't get the machine to run any programs. The machine will start up correctly and traverse the x,y,z points. I then enter into run program mode and select a program. I can start the spindle but as soon as the program gets to the first block where it has to move the table the spindle will stop and the program will also stop with the * flashing on the screen. I have read the manuals for a few hours and can't quite get past this point. If I run the program in single block mode it does the same thing. As soon as it gets to a block where an axis moves the the spindle stops and the program stops. Thanks for any help and please have patience with me because I am a newbie.
Old 10-08-2007, 04:21 PM
gus gus is offline
gus is on a distinguished road
Is it not seeing the spindle start?
low on oil?
Old 10-08-2007, 04:26 PM
The oil level looks good. It says in the manual that if it is low on oil that the control won't power up. How could I check to see if it sees the spindle start? Thanks again for any help.
Old 10-08-2007, 06:06 PM
gus gus is offline
what machine is it?
Old 10-09-2007, 05:18 PM
Its a series 1 Bridgeport 6HP with TNC 155 control.
Old 10-09-2007, 07:22 PM
bbrreid is on a distinguished road
check the spindle drive card or lower spindle speed in the program to 500rpm
my Beaver mill came up with Gross Position error C when the axis started to move. I replaced a resistor on the spindle drive card and that fixed the problem.
I now have a new problem the monitor has gone down. can I use a PC monitor ?
BR
Old 10-10-2007, 03:57 AM
liveforever8281 is on a distinguished road
Hi there,
There are many factors when programing in Heidenhine that will make the machine sit there and not move any where. If you e-mail me your program I will be happy to look over it for you to see if there are any problems with it.
Regards Peter
liveforever8281@yahoo.com
Old 10-11-2007, 02:29 PM
The machine is not at my house so next time I go over to it I will write down one of the programs in it. I haven't actually written any programs myself yet. I was just trying to run one of the programs that the previous owner had programed in already. I have tried several different ones with all of the same results though. This machine is new to me. I just purchased it and have not had it successfully running yet. I built a rotary phase converter using a static phase converter and a 15 hp 3 phase motor. I followed all of the diagrams and am pretty sure everything is hooked up correctly but this is the first time I have done it. Are there any parameters that could be causing this problem? It doesn't actually come up with any error messages that I see but the * is flashing on the control screen indicating the program has stopped. If I push the start button again the * will quit flashing for about 15 seconds and then start again. Thanks again for any help. I am getting close to having to pay someone to come look at this though. Does anyone know of someone around the Eleva - Strum, WI area that would be able to service this machine or know the controls well enough to at least tell me if there is something wrong with the mill?
Old 10-11-2007, 03:13 PM
gus gus is offline
Does the machine do everything in manual mode? all 3 axis move, spindle fwd and reverse?
Old 10-11-2007, 04:57 PM
All of the axis move with the joysticks in manual mode. The spindle will start up in manual mode but it is going in reverse. I haven't really tried to run it in manual mode.
  #11   Ban this user!
Old 10-11-2007, 07:10 PM
gus gus is offline
If the spindle is running backwards, one might suspect that the 3 phase needs to be swapped around. You need to find out which 2 wires feed the transformer that feeds the control, then make sure the generated leg is not on one of those. and keep it that way after you swap 2 of the three
  #12   Ban this user!
Old 10-12-2007, 07:28 AM
It has crossed my mind that the first 2 legs of my 3 phase could be switched but I wasn't sure if that would cause the problem I am having. I can switch them around this afternoon if I can get back over to the machine. Is there a way to test the phase wiring with a standard fluke meter? Thanks again.
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 08:29 AM
Bridgeport Series 1 Heidenhain TNC 145 pestana1957 Bridgeport and Hardinge Mills 27 08-05-2009 05:13 PM
Fanuc Series 15-M Trouble uploading Ladder Program grege101 Fanuc 5 12-13-2007 09:38 PM
Series 1 Standard remanufacture program seanm8966 CNCzone Club House 3 11-08-2005 04:05 PM
Bridgeport Eztrack Series II -Ferror Program yuso Bridgeport and Hardinge Mills 2 05-23-2005 12:44 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
