Old 10-03-2007, 11:06 PM
Productos is on a distinguished road
Homing Problem After Reinstalling Servo
I have a Bridgeport Interact 1 with a Heidenhain 151 Control. The Y axis servo burned and I had it sent out and repaired. After reinstalling the motor the axis will move, but will not go home correctly when starting up the machine. While going to the Y axis reference point it appears to have gone to the correct point, but the message remains on the screen and the machine freezes.
Is there an adjustment procedure for reinstalling the servo?
If anyone have a suggestion please help I need the machine up.
Thanks,
Peter
Old 10-04-2007, 07:05 AM
RMARCH's Avatar
RMARCH is on a distinguished road
When you remove a motor you should measure how far the pulley is mounted on the motor shaft so when you replace it you can put it back near the correct spot. I would try moving the pulley a little so when you home the machine it hits the home limit switch.
Old 10-04-2007, 07:07 AM
Moderator
machintek is on a distinguished road
See if this helps.
George
File Type: pdf INTERACT AXIS DRIVE SET UP TNC151_155.pdf‎ (37.4 KB, 85 views)
Old 10-04-2007, 07:22 AM
gridley51 is on a distinguished road
I can email you the pages from the manual if you send me your email address.
The software limits have to be reset after the servo has been reinstalled.
Mark.
Old 10-04-2007, 09:43 AM
gus gus is offline
gus is on a distinguished road
re
Yeah, possible I suppose that the settings on the servo amp are so off that it is never ever actually getting to the endpoint, but seems slim.
Is it moving smoothly, normally when referencing?
AFAIK all it does while homing is put out x.x volts + - [depending on parameter] and the control will I believe look at the encoder pulses to make sure they are there[IOW you can get an encoder error while homing] but it doesn't look for the home pulse until it hits the trip dog. Now maybe if it hit the trip dog and saw the home pulse at the same time it would freak it out.
Old 10-04-2007, 12:36 PM
After replacing an axis motor the soft limits in the parameters have to be reset.I have emailed him the relevant pages from the manual.
Mark.
Old 10-04-2007, 01:18 PM
Dirky is on a distinguished road
interact axis drive set up
Originally Posted by machintek View Post
See if this helps.
George
George.I just read this...you sent this info to someone having trouble getting thier axis' to home correctly......should I need to do this....what behavior would I look for to determine if my machine requires this procedure ?
Old 10-04-2007, 03:14 PM
Thanks for the replys and suggestions.
Unfortunately I don't think I have enough electronic knowledge to attempt the instructions George sent me, and the instructions I received from Mark assumes that I can do the "pass over reference point" sequence. However that is where I get stuck. While referencing the Y-axis it just runs by the first linit switch, and hits the extreme limit switch, and then I'm stuck again. I tried to rotate the pulley 180 degrees, but that had no effect. I checked the linit switch with an ohm meter and it appears fine.
Any more ideas?
Peter
Old 10-04-2007, 07:06 PM
I just switched the X and Y-axis boards, but the problem remains the same. I assume that at least means that the problem is not in the boards?
Old 10-04-2007, 07:19 PM
gus gus is offline
>>>While referencing the Y-axis it just runs by the first linit switch, and hits the extreme limit switch, and then I'm stuck again. I tried to rotate the pulley 180 degrees, but that had no effect. I checked the linit switch with an ohm meter and it appears fine.<<<
That is new information
It should stop dead when it hits the trip dog[ the first switch is not a limit switch] My first instinct with that symptom would be that the trip dog is not tripping. Assuming all the parameters are known good[ this machine ran for you before this happened] that is the first thing to double check
Old 10-04-2007, 08:22 PM
Moderator
It may not be seeing the marker pulse. Swap motors.
The drive tuning procedure is just that. Every so often due to use, age and heat the values of electrical components can change as well as the brushes wearing and the magnets decaying in the motors. This may require some adjustment. replacing a motor or a servo drive board may require this procedure also.
George
  #12   Ban this user!
Old 10-04-2007, 09:02 PM
Thanks gus,
Part of the problem I guess is I'm dumber than a doorknob when it comes to electronics and machine repair. Therefore I probably have not explained the problem correctly yet and my vocabulary must most certainly be off.
As far as the parameters being good - yes and no. The previous owner (I've had the machine for about 8 months) changed batteries with the power off as I was in the process of buying it. (He did not have a manual, nor the parameters). I was able to download a set of parameters from the internet, and lo and behold the machine has been working since. I'm sure that there are errors in backlash and such, but it worked fine for what I need it for, so I did not want to mess with anything.
I did check the switch (limit and "trip dog") with an ohm meter as I mentioned, and it seems to work correctly.
If you are familiar with this particular type of control and machine, you know that when doing the pass over reference sequence, if the machine is already at the reference point, the text on the screen is black with yellow background, and it first backs off then returns. If it is away from the ref point the text is normal, yellow on black. I backed all axis (by turning the belts) from the switches and then pushed the trip dog switch by hand. All of them including Y then gave me the black text with yellow background, so some sort of signal is being sent out. However when I try to do the homing the result is the same. The Z axis is fine and the Y-axis blows right by the trip dog, and I'm stuck.
Is there a way that a layman like myself can check the trip dog out, or do I need to find someone that knows what they are doing?
reinstalling x axis servo and encoder fcycles Milltronics 29 12-11-2007 12:30 PM
partner 0-5 centurion 5(homing problem) irtaza Milltronics 17 08-02-2007 10:16 PM
Homing problem in mach2 atifeh Machines running Mach Software 7 12-19-2006 07:25 PM
Problem With Homing X Axis elalto Mach Software (ArtSoft software) 1 09-15-2006 07:28 PM
Homing Problem V4.0.1 BMaynard TurboCNC 5 04-13-2006 01:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710
