Old 09-30-2007, 12:08 AM
Dirky is on a distinguished road
How does the heidenhain 151 determine if dc voltage is present ?
Does anuone KNOW how the heidenhain 151 control determines if there is dc voltage available ? Is there a specific line into the control for this ? and is it connected to a vm inside the control ? Is it possible that my machine does NOT have missing dc voltage but the control is simply not capable of reading it ?.....Ideas
Old 09-30-2007, 04:19 AM
gridley51 is on a distinguished road
The connections are shown in the attached PDF.This is for a 151 B/Q,if yours is a 151 A/P you will have to go to the Heidenhain site and download the proper manual.
Page 21 tells the terminal numbers for 24v at the control unit.
http://filebase.heidenhain.de/doku/o...b/23268625.pdf
A fault in the control would usually show up in the self test before you get to this stage.
Mark.
Old 09-30-2007, 12:29 PM
Thanks Mark.....Mine is the 151b....and I have the terminal chart for it.....I suspect you are correct and I hope the fault is in the EMO string...I just cant find it yet.......how many things does this darn control check before it will turn on anyway...? limits switches........oil level.....???? what else ????
Old 09-30-2007, 03:49 PM
Do you have an electrical drawing for this machine?
Old 10-01-2007, 08:45 AM
not one that I can read....a few have offered up some but they are of such poor quality that I can not see the wire or terminal numbers
Old 10-01-2007, 11:03 AM
RMARCH's Avatar
RMARCH is on a distinguished road
I have a couple TNC151 schematics, one i think is for 151A and i know the other is for the 151B. The files are to large to post here so i will need your email address. Hope they help !!
Help..Stuck at relay ext dc voltage missing but dc voltage OK ? Dirky Bridgeport and Hardinge Mills 24 11-27-2007 07:33 AM
How to Determine Lathe Size bill south General Metal Working Machines 1 10-14-2006 09:54 AM
Is it possible to determine which phase is which? phantomcow2 Stepper Motors and Drives 1 02-25-2006 05:53 AM
How Can You Determine.... jonbanquer Fadal 12 01-08-2004 06:16 PM
Get Referals for present and future CNCadmin Product Announcements & Manufacturer News 0 04-20-2003 09:58 AM
