Old 09-27-2007, 08:42 AM
Oviksnc is on a distinguished road
TNC150 memory upgrade?
Hi. Tried the search function but didīnt find anything of interest!
Is there any way to upgrade the internal memory of the TNC150 so you can use more than 1200blocks? Would be great when weīre using programs thatīs over 5000blocks and have to run/erase/upload/run and so on....
Also have a question about the parameters. We rewrited new parameters yesterday due to a battery failure, but when we run the program we need to press the start button the first 3 blocks until the machine takes over and runs the following blocks for itself. Does any of you know how to fix this small but annoying problem?
Thanks.
/Johan
OviksNC/Sweden.
Old 09-27-2007, 12:22 PM
gus gus is offline
gus is on a distinguished road
re
No memory upgrades, not a PC.......
I don't think that the parameters are the source of your problem, I think there may be a programming error, IE, an M0 at the end of the first three lines or something
Old 09-27-2007, 08:58 PM
Moderator
machintek is on a distinguished road
This was not meant to be a 3D machine. When it was made in the middle 1980's most programs were written by hand and were short.
You may have some safety lines in the beginning of your program. I can think of the first cycle start to start the program This should be followed by a tool change. This requires a cycle start again. So I can account for 2. You have to read and understand the program and machine to figure out the third cycle start. Try this. After the tool change, start the spindle and then hit cycle start.
George
Old 09-27-2007, 11:52 PM
Ok thanks! Itīs a great machine for a small amount of money. To bad with the memory i saw this yesterday the first lines in the program doesīnt make any sense. It works perfectly now.
Thanks.
/Johan.
OviksNC/Sweden.
16M memory upgrade 1ctoolfool Haas Mills 6 04-26-2010 06:32 AM
Bridgeport TNC150 to TNC151A upgrade UK Dave Bridgeport and Hardinge Mills 9 02-13-2007 09:42 AM
Memory upgrade for Mazatrol T32-3??? Fendertok Mazak, Mitsubishi, Mazatrol 1 12-10-2006 01:25 PM
Brother TC-22A memory upgrade fred-01 General Material Machining Solutions 0 01-26-2006 04:39 AM
1985 VMC-40 OS and Memory upgrade 2001lightning Fadal 4 10-12-2005 10:53 AM
