Old 09-25-2007, 06:59 AM
Number Six is on a distinguished road
Width of door for Series 1 access ?
First Post!! Yay!
Next year I plan to get a series 1 CNC for my home workshop/lab (er not yet built!) and I'm currently in the process of putting a gate in my garden wall for access. Anyone know off the top of their head how wide I should make the gate to easily get the machine in? I heard 1700mm but this seems a little wide..
No. 6
Old 09-25-2007, 11:10 AM
gus gus is offline
gus is on a distinguished road
A series one boss or interact machine needs maybe 4 feet max, a long table standard bridgeport might need more
Old 09-25-2007, 12:19 PM
Dennis Storzek is on a distinguished road
I concur. My Series I BOSS measures 46.5" (1181mm) from the left edge of the table over the X axis ball screw nut on the right side, and I'd rather not be banging that nut against anything, so 48" (1200mm) would be the absolute minimum. Since 48" is a bit wide for a single door (but perhaps not a gate) I can see where the 66" (1700mm) recommendation comes from; a 66" double door, with only one 33" leaf normally in use. That is, indecently, exactly what I have in my shop.
Manual Bridgeports with longer tables can go through narrower doors, as the machine can go through at an angle and the table cranked back and forth. With the big electrical boxes on a DOSS, there is not much to be gained, even if one disconnects the stepper or servo to move the table by hand.
Old 09-26-2007, 04:00 AM
Thanks very much guys..
I'll be making it 1500 then as its single leaf.
Hopefully will get the beast sometime next spring!
No. 6
timing belt width? JFettig Benchtop Machines 8 01-28-2010 05:34 PM
Pulse width for optoisolated breakout board? toolbox911 Stepper Motors and Drives 2 02-22-2006 11:59 PM
Problem with slot width Angus General CAM Discussion 9 02-03-2006 11:51 PM
Milling: low depth passes or all the width? PEU DIY-CNC Router Table Machines 8 11-02-2005 05:57 PM
Visual Basic Controller - pulse width? dwwright Visual Basic 16 08-03-2005 11:57 AM
