Old 09-19-2007, 10:29 AM
DaveinUK is on a distinguished road
Retrofit kits for Boss 6
I have two machines a Boss 5 and a Boss 6. The Boss 5 is still working very well with the odd transistor blowing now and again. The reason for this post I'm thinking of a possible retrofit on the Boss 6 as the machine seems to have many small problems and remains unused. Due to the lack of hours in the day I thought of a the retrofit. I've looked at the Centroid website and the fit looks good. However I'm in the UK, anybody know of any other retrofits, as it would be good to get both running at the same time.
Thank's
Dave
Old 09-19-2007, 04:57 PM
colin1544 is on a distinguished road
boss 5 & 6 retrofits
Hello Dave if you are looking at the centroid retrofit kits also have alook at the AJAX CNC site this is the do it yourself version of the Centroid, I have a Boss 5 machine converted with an AJAX system I have had it installed for about the last 4 years and I use it for Hobby work and small batch runs on machine parts it has been very reliable accurate and basically easy to program. The downside of the system is you need to take a look at what facilities you need from the control as some of the useful one's such as programable speed control, engraving, MPG control, are all extra's but on the whole it is a very good system and easy to retrofit. If you want to have a natter about the system give me a call on 01159389014 up to the 23 of September then six weeks after away on holiday, it's also a good time to buy with the exchange rate at about $2 to the £1. Cheers Colin
BP boss retrofit? sdeering Bridgeport and Hardinge Mills 21 12-17-2011 08:40 PM
J&J Engineering retrofit kits? nlh General CNC (Mill and Lathe) Control Software (NC) 3 05-05-2008 05:21 PM
Boss 4 retrofit help needed. wyobmf Bridgeport and Hardinge Mills 6 07-26-2006 06:46 PM
Bridgeport Boss Retrofit help moto21 Bridgeport and Hardinge Mills 7 06-09-2005 10:32 PM
Have Boss 9 with less than 200 total hrs. Looking for retrofit. lilb93 Bridgeport and Hardinge Mills 8 03-27-2005 11:40 AM
