Old 09-13-2007, 07:41 PM
markhas is on a distinguished road
X Axis RE RE visited
I have a BP S1 RR with a Hill Billly BOB running Mach. The machine has been running well for a year. Recently, I have been having troubles with my x axis and now it stopped working. I have gone through all of the diodes and transistors several times. I noticed now that I have no voltage at wire 24 (this is the wire that feeds the infamous FU12 fuse) I tried to trace this wire but I can't. I have the schematic, but it is photocopied and I can't make out anything. Can anyone help me out please? If I could get a good resolution schematic that shows me where this wire comes from, it would be great. otherwise, if someone could just tell me, that would be fine too.
Thanks Much!
Mark H
Old 09-13-2007, 10:25 PM
Moderator
machintek is on a distinguished road
I have no idea what is kept with this conversion. But fuse 12 is the DC side of the bridge rectifier. I believe fuse 15 is the AC side of the bridge. The bridge is fed by T2.
George
Old 09-13-2007, 11:47 PM
George,
Thanks for the reply. I must have a broken wire somewhere. My power cabinet checks out OK (including FU 15).
Mark
Old 09-14-2007, 08:12 PM
Moderator
I had one very unusual case where a BOSS 5 had a lack of power From T2 to the bridge rectifier.. This is a number 14 wire that does not move, yet it went open. Go figure. It was a illogical problem and took a little while longer to find.
George
Old 09-14-2007, 08:32 PM
George,
Thanks, that sounds exactly like my problem. Is there any easy way to get a t those bridge rectifiers? They are buried near the transformer, right?
Mark
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 11 05-23-2012 09:31 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Using X axis table moter for knee X axis imatoymaker General Metal Working Machines 1 09-10-2007 07:23 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
INCREDIBLE Forum...but why no Link-Visited Indication? polyNuker Forum Questions or Problems 1 01-09-2007 07:44 PM
