  #13   Ban this user!
Old 07-16-2004, 08:38 PM
unterhaus is on a distinguished road
Originally posted by snaggletto
Hello,
The machine I have is very similar (if not exactly) to the one in this Ebay auction.
http://cgi.ebay.com/ws/eBayISAPI.dll...816048754&rd=1
I did some looking through J&L and MSC and saw some #30 taper quick change holders. At the small end of the taper (where the drawbar would go) there is a short length of straight diameter. Also, if I remember correctly, there is a flange with 2 opposing notches cut out (lines up with the tangs in the spindle).
In the Ebay ad above, there is a picture of some tooling included with the mill. It is kinda hard to see, but the tapered shank is tapered all the way, and looks like it's built to take a pull stud like CAT 40/50 holders. Furthermore, this tooling has no flange, but just 2 tangs.
Most BP cnc machines came with NMTB 30 taper. This style can still be purchased from msc and on ebay, but most manufacturers of new machines this size use Cat 40. The auction shown above went dirt cheap for a Series 1 with tooling. The tooling appears to be Universal Quik-Switch 200, which was an option. The Universal tooling is a little nicer. I don't think that it uses pull studs, as the two tangs hold them into the spindle.
Advice on Bridgeport BPJ to CNC ToMMY2ooo Bridgeport and Hardinge Mills 34 09-14-2005 03:54 PM
Bridgeport Series 1 CNC w/ BOSS 5 serial cable needed bbuonomo Machine Problems, Solutions , Wireless DNC, serial port 16 05-30-2005 05:05 AM
Trying to drip feed a cnc boss6 bridgeport cncboss6 Bridgeport and Hardinge Mills 2 03-11-2005 06:28 PM
Bridgeport cnc conversion? Bryscnc Bridgeport and Hardinge Mills 10 03-10-2005 07:07 PM
Bridgeport CNC Conversion Recipe? Eric General Metal Working Machines 6 02-16-2005 09:58 PM
