I hope this helps
as most of you know i don,t know what im doing most of the time, but i,ll keep blundering along. i need to make a rs232 cable but the diagram in the book goes from a 25 pin to a 25 pin so how do i do it with a 25 pin on the bpr2c3 with heidenhaintnc145 to a pc witha 9 pin plug. i,ll try anything and i would appreciate any help
thanks Dar
ps just a funny story. i scrapped a job the other day and couldn,t do it after 2 more trys. my wife thin told me she knew what was wrong with me.
i told her after 49 years togeather she should have a list. she then showed me something i had not noticed. i had a ceiling fan runningunder a 4ft 4 tube light. with the position of my new mill it was right over head and acting like a strobe light. it really screwed up my head. so then the worst happened [i had to tell her she was right] woo is me
I hope this helps
This is the cable that I use from the 25 way on my TNC151b to the 9 way serial port on my PC
(25way TNC) <9 way PC>
(2) - <2>
(3) - <3>
(4) - <8>
(5) - <7>
(6) - <4>
(7) - <5>
(20) - <6>
Andrew Mawson
East Sussex, UK
Pic also available at:
http://www.aggsoft.com/cnc-dnc/heidenhain-tnc-145.htm
Just a small warning, don't ground both ends of the cable, ok to do one end, it helps with the sheilding, but if you do both ends IT MAY blow a board in the control
I have complete cable and software setup for communicating via 232 that i bought off ebay and never used.
I'd sell for $40 Canadian
You can also order a 25 ft cable with DB9 for PC to DB25 for CNC, any make / model off our website for $37.50.
Longer lengths are available and if you want to make it yourself, we have some wiring diagrams and recommended raw cable on our site.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
