Old 09-11-2007, 10:35 AM
cut more is on a distinguished road
R2E3 quill rotate?
Hello,
I have an R2e3 that when the quill is ~1/2 down I can turn the outer part of the quill(the chromed part) back and forth about 2 degrees. Is this anything to worry about? If so what would I do to fix this.
I sometimes get strange surface finishes with this mill and maybe this is why.
Thanks for any replies.
Cutmore
Old 09-12-2007, 07:49 AM
gus gus is offline
gus is on a distinguished road
re
I think the only thing that restrains it is the arm that actuates the limit switches
Old 09-13-2007, 06:38 AM
Thanks for that,
Do you have the manuals for this model by any chance? I have the operating, programming and maintenance but not the repair manual.
Cutmore
Rotate and copy bdrmachine Solidworks 6 02-02-2007 09:56 PM
how to rotate solid model on XZ or YZ plane qmas99 Surfcam 3 12-08-2006 09:35 AM
Rotate pulleys using less energy. Jigar111 Mechanical Calculations/Engineering Design 2 12-03-2006 12:51 PM
copy and rotate, help (okuma) zooloader G-Code Programing 13 06-26-2005 07:01 PM
Long X-axis methods: Rotate the nut? OCNC DIY-CNC Router Table Machines 4 11-23-2004 04:13 PM
