Old 09-10-2007, 08:03 AM
ataylor_316 is on a distinguished road
Question ANILAM CRUSADER II Problem
We have a Bridgeport Series I with the Crusader II controller. The problem is the Z-axis is no reading in the + direction, it reads in the - direction. The scales are OK I check them and switched them around with the same results. It trips out the servos whenever you try to move any axis with the manual buttons. I noticed that the Z is slowly moving in the + not reading when the machine is turned on, and I hear a high pitch whine from each servo. Does this sound like a board in the controller.
Old 09-12-2007, 10:44 AM
bborb is on a distinguished road
Any LED's in cabinet indicating status when alarms?
Old 09-21-2007, 06:04 AM
outctrl is on a distinguished road
Hook up one axis at a time and move with handwheels to make sure they are counting in right direction. If so, run in test mode to check balance and signal settings,. If you can use meter, check with that instead. Sounds tho that you have z reader head problem.
My New/Old Anilam Crusader M has a problem L98FIERO General CNC (Mill and Lathe) Control Software (NC) 2 08-15-2008 07:10 AM
Anilam Crusader II - Crusader 2 Training DVDs Mike Mattera Product Announcements & Manufacturer News 2 07-08-2007 09:31 PM
Anilam Crusader M problem Rot Iron Racer General CNC (Mill and Lathe) Control Software (NC) 0 04-18-2007 02:15 PM
Anilam Crusader M DNC hsmcnc General CNC (Mill and Lathe) Control Software (NC) 0 02-20-2007 04:06 PM
Anilam Crusader 2 Help porsche1220 General CNC (Mill and Lathe) Control Software (NC) 3 04-09-2006 12:37 PM
