Hello. I'm having a problem with my R2E3. It has the BOSS 8 control. I turn on the machine and it powers up fine, no errors. I enable the drives and they turn on. But my X-axis will VERY slowly move or drift by itself. Now when I go to home the machine the Z-axis homes first no problem, but then the X-axis will rapid about 1-inch towards its home position and then the drives will kick out and I get an "axis limit" error. Every time I enable the drives my X-axis will drift really slow by itself. I can move it in JOG mode in both directions before executing the machine HOME. But whether I press the + or - direction it will rapid fast in that direction about 1" and then the drives kick out and I will get the "axis limit" error. The machine had its initial problem in the middle of running a program. The x-axis did a programed rapid move and then the drives kicked out, spindle turned off, and I had an "axis limit" error. Now I've had this x-axis drift problem ever since. I cleaned the connectors on the NC400 boards. I tried swapping the controllers but that didn't make a difference. I've had this machine for 3 years now and this is probably the first problem I've had with it. Anyone have any suggestions? |
| If an axis drifts when powered it has an open position loop. This could be the encoder, or cable, or a board. Swap the motor with the Y axis and see if the problem follows the motor. George
| Axis Motion Knob/Feed Override Series I R2E3 | krz2_2000 | Bridgeport and Hardinge Mills | 0 | 07-27-2007 08:20 AM |
| R2E3 Boss 8 Axis limit problem | hrhoward | Bridgeport and Hardinge Mills | 4 | 05-30-2007 08:24 PM |
| Z Axis problem | studysession | Mach Software (ArtSoft software) | 2 | 05-05-2007 06:06 PM |
| R2E3 X Axis ballscrew cover | s1j1m10 | Bridgeport and Hardinge Mills | 1 | 08-23-2006 06:43 PM |
| Z axis going nuts on my R2E3 | Creative Tool | Stepper Motors and Drives | 1 | 06-08-2006 11:37 PM |
