My bridgeport clone has 2hp. 3phase motor, 1,720rpm . I would like to know if it is possible that the rpm is not running as the way it should be. I use to machine 304 stainless steel at a certain SFM before, but know I can't cut it as the way I use to The SFM is 50% slower now. If I run it faster the endmill will break ![]() Is it possible that the motor is running at a slower speed now [Confused] The motor sounds fine, but I do not know if it running right. Is it possible guy |
| I use a tach to check the spindle speeds against the pulley ratios. That way no doubt if the spindle matches the specs. Shouldn't be much difference but you'll probably find some. I found a tach on EBay for $30 and it's paid for itself in setting accurate speeds on both my variable speed mill and lathe. |
| Inaccurate feedrate | alfalfa | CamSoft Products | 39 | 05-18-2007 08:35 AM |
| Speed and win xp | ALEXCOMO | FeatureCAM CAD/CAM | 3 | 10-13-2006 06:05 AM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
| Travel distance is inaccurate. | thuffner3 | TurboCNC | 11 | 12-15-2004 08:32 AM |
| min speed exceeds max speed for axis "x"? | ljoe1969 | TurboCNC | 4 | 01-19-2004 07:49 AM |
