Old 08-28-2007, 10:55 PM
dougputt is on a distinguished road
Question Another Bridgeport Series 1
Just got a Bridgeport/Textron series 1 with BOSS control. I don't know anything about CNC, i've been reading a lot of Damae's posts.
Not sure if the unit is operational but sure is pretty! Would really appreciate any info on hooking into the RS232 plug and running off Mach 3 software!
Regards
Doug
Old 08-30-2007, 11:16 PM
yes, beleive it or not it does work! Now if i only new how to run the damn thing!
Old 08-31-2007, 04:50 AM
creep_pea is on a distinguished road
Hi
You can use the RS232 port for transferring programs in to the machine but it can't be used to run the machine of Mach3, to do this you have to wire the drive signal wires to a breakout board and from here into the back of your computer, HillBilly sells a breakout board and instructions on how to do this.
Chris
Old 08-31-2007, 07:50 AM
Thanks very much! I've sent hilbilly an email hopefully i can get a board from him! I take it you've used his board with great success?
Old 09-02-2007, 01:09 AM
keebler303 is on a distinguished road
I have used the board with great success. It is relatively easy to install and works flawlessly.
Great product from Darek (hillbilly).
Happy Milling
Matt
Old 09-02-2007, 10:44 AM
i'm having great difficulty getting my PC to talk to machine thru the amp connector. anyone have any ideas? anyone have pin assignment diagrams?
Regards
Old 09-04-2007, 05:32 PM
Thanks for the info guys. i've tried pretty much everything, Chris sent me some good bulletins which i went over. Still no avail. I pulled the ERS board out and noticed two empty sockets marked TP1 & TP2 anyone familiar with these?
Old 09-06-2007, 07:46 PM
Well punched some code into the machine and works (usually) sometimes it drops some code for some reason but I plan on putting the hilbilly board in it anyways this RS232 communication thing sucks!
Bridgeport Series II Info TPMX Bridgeport and Hardinge Mills 5 01-27-2007 07:56 PM
Oil to lubricate Bridgeport Series 1? biomed_eng Bridgeport and Hardinge Mills 2 09-27-2006 02:08 PM
Bridgeport Series 1 CNC ID markhas Bridgeport and Hardinge Mills 2 05-30-2006 11:06 AM
Bridgeport series 1 or 2 ?? drill Bridgeport and Hardinge Mills 5 11-27-2005 09:17 PM
Bridgeport Series 1 CRAZYRICH General Metalwork Discussion 2 07-27-2005 08:54 PM
